Automated SSL Certificate Monitoring and Renewal with Notion and Telegram
Created by: Frank Chen || frankchen
Frank Chen
Last update 22 days ago
Categories
Automatically fetch existing domains from Notion's Database and verify the validity of SSL certificates through SSL-Checker. If the validity period is less than 14 days, send a Telegram message notification and trigger SSH remote automatic refresh. Successful refresh notification will be sent through Telegram.
This can prevent problems with the server-side automatic refresh program, which may cause unexpected service interruptions.
Main use cases:
  • Notion store domain.
  • Telegram receives warning messages.
  • Remotely trigger Certbot to refresh SSL.
How it works:
  • Record who triggered this workflow, because if there is a credential that is about to expire, this workflow will be triggered repeatedly.
  • After getting all the domains from Notion, send an http request to SSL-Checker.
  • After getting all the SSL-Checker results, add the validity label. And use the IF node to check if there are any certificates that are about to expire.
Then there are two workflows:
  • If there is a certificate that is about to expire: send an SSH command to the remote control server to refresh the certificate, notify through Telegram, and call this workflow again to re-verify the validity of the SSL certificate.
  • If the validity period of SSL is normal: then refresh the data on Notion, and if a re-called workflow is detected, Telegram will be used to notify that the SSL has been updated.
