Build a RAG system with automatic citations using Qdrant, Gemini & OpenAI
Created by: Davide || n3witalia
Davide
Last update 2 days ago
This workflow implements a Retrieval-Augmented Generation (RAG) system that:
  • Stores vectorized documents in Qdrant,
  • Retrieves relevant content based on user input,
  • Generates AI answers using Google Gemini,
  • Automatically cites the document sources (from Google Drive).
Workflow Steps
  1. Create Qdrant Collection
    A REST API node creates a new collection in Qdrant with specified vector size (1536) and cosine similarity.
  2. Load Files from Google Drive
    The workflow lists all files in a Google Drive folder, downloads them as plain text, and loops through each.
  3. Text Preprocessing & Embedding
    • Documents are split into chunks (500 characters, with 50-character overlap).
    • Embeddings are created using OpenAI embeddings (text-embedding-3-small assumed).
    • Metadata (file name and ID) is attached to each chunk.
  4. Store in Qdrant
    All vectors, along with metadata, are inserted into the Qdrant collection.
  5. Chat Input & Retrieval
    • When a chat message is received, the question is embedded and matched against Qdrant.
    • Top 5 relevant document chunks are retrieved.
    • A Gemini model is used to generate the answer based on those sources.
  6. Source Aggregation & Response
    • File IDs and names are deduplicated.
    • The AI response is combined with a list of cited documents (filenames).
    • Final output:
      AI Response
      Sources: ["Document1", "Document2"]
Main Advantages
  • End-to-end Automation: From document ingestion to chat response generation, fully automated with no manual steps.
  • Scalable Knowledge Base: Easy to expand by simply adding files to the Google Drive folder.
  • Traceable Responses: Each answer includes its source files, increasing transparency and trustworthiness.
  • Modular Design: Each step (embedding, storage, retrieval, response) is isolated and reusable.
  • Multi-provider AI: Combines OpenAI (for embeddings) and Google Gemini (for chat), optimizing performance and flexibility.
  • Secure & Customizable: Uses API credentials and configurable chunk size, collection name, etc.
How It Works
  1. Document Processing & Vectorization
    • The workflow retrieves documents from a specified Google Drive folder.
    • Each file is downloaded, split into chunks (using a recursive text splitter), and converted into embeddings via OpenAI.
    • The embeddings, along with metadata (file ID and name), are stored in a Qdrant vector database under the collection negozio-emporio-verde.
  2. Query Handling & Response Generation
    • When a user submits a chat message, the workflow:
      • Embeds the query using OpenAI.
      • Retrieves the top 5 relevant document chunks from Qdrant.
      • Uses Google Gemini to generate a response based on the retrieved context.
      • Aggregates and deduplicates the source file names from the retrieved chunks.
    • The final output includes both the AI-generated response and a list of source documents (e.g., Sources: ["FAQ.pdf", "Policy.txt"]).
Set Up Steps
  1. Configure Qdrant Collection
    • Replace QDRANTURL and COLLECTION in the "Create collection" HTTP node to initialize the Qdrant collection with:
      • Vector size: 1536 (OpenAI embedding dimension).
      • Distance metric: Cosine.
    • Ensure the "Clear collection" node is configured to reset the collection if needed.
  2. Google Drive & OpenAI Integration
    • Link the Google Drive node to the target folder (Test Negozio in this example).
    • Verify OpenAI and Google Gemini API credentials are correctly set in their respective nodes.
  3. Metadata & Output Customization
    • Adjust the "Aggregate" and "Response" nodes if additional metadata fields are needed.
    • Modify the "Output" node to format the response (e.g., changing Sources: {{...}} to match your preferred style).
  4. Testing
    • Trigger the workflow manually to test document ingestion.
    • Use the chat interface to verify responses include accurate source attribution.
Note: Replace placeholder values (e.g., QDRANTURL) with actual endpoints before deployment.
Need help customizing?
Contact me for consulting and support or add me on Linkedin.
