Monitor competitor SEO changes with CustomJS Scraper, Sheets & Slack alerts
Created by: CustomJS || customjs
CustomJS
Last update 20 hours ago
Categories
This n8n workflow demonstrates how to monitor competitor websites for SEO changes by scraping content and updating a Google Sheet. It uses the Scraper node from customjs.space to extract HTML content and parse key SEO elements like title, <h1>, <h2>, and meta description.
What this workflow does
  • Reads a list of competitor websites from a Google Sheet.
  • Uses the CustomJS Scraper node to fetch raw HTML for each website.
  • Extracts important SEO data:
    • Page title
    • <h1> headings
    • <h2> headings
    • Meta description
  • Updates the Google Sheet with the latest scraped values and a timestamp.
  • Compares the new values with the previous ones:
    • If changes are detected, a Slack notification is sent.
Requirements
  • CustomJS API key for the Scraper node.
  • A Google Sheet containing competitor website URLs.
  • Slack workspace (optional, for notifications).
Workflow Steps
  1. Schedule Trigger
    Runs automatically (weekly by default, adjustable as needed).
  2. Google Sheets – Get Competitor URLs
    Reads competitor website URLs from the configured sheet.
  3. CustomJS Scrape – Website
    • Inputs each website URL.
    • Returns raw HTML text for analysis.
  4. Code – Extract SEO Elements
    Parses the HTML to extract:
    • Title
    • H1s
    • H2s
    • Meta description
  5. Google Sheets – Update SEO Data
    Updates the sheet with the new SEO data and a current date.
  6. If – Check for SEO Changes
    Compares old vs. new values.
  7. Slack Notification – Alert on Changes
    Sends a message to Slack when updates are detected.
Usage
  1. Get API key from CustomJS
    • Sign up on the CustomJS platform.
    • Navigate to your profile page.
    • Click “Show” to reveal your API key.
  2. Set Credentials for CustomJS API in n8n
    • Copy your API key into a new CustomJS credential.
  3. Prepare your Google Sheet
    • Create a sheet with a column named Websites.
    • Enter competitor URLs (must start with https://).
  4. Run or schedule the workflow
    • The workflow will scrape competitor sites, update the sheet, and notify you of any SEO changes.
Example Output
Google Sheet after update:
Websites Title Meta Description H1s H2s Date
https://example.com Example Title Example meta description Example H1 Heading Example H2s 2025-09-07 12:00:00
Slack Notification Example
⚠️ Competitor SEO Change Detected!
Website: https://example.com
Title
  • Old: Example Title
  • New: New Example Title
Meta Description
  • Old: Example meta description
  • New: Updated example meta description
H1s
  • Old: Example Heading
  • New: Updated Heading
H2s
  • Old: Example Subheading
  • New: Updated Subheading
Date: 2025-09-07 12:00:00
Customization Tips
  • Change scraping frequency in the Schedule Trigger (daily, weekly, etc.).
  • Track additional elements by extending the regex in the Code Node.
  • Send alerts to other platforms (e.g., Email, Microsoft Teams, Discord) by swapping the Slack node.
  • Store results in a database instead of Google Sheets if long-term history is required.
