Give AI agents power to get, create, update issues with Linear tool MCP server 💪
Created by: David Ashby || cfomodz
David Ashby
Last update a month ago
Need help? Want access to this workflow + many more paid workflows + live Q&A sessions with a top verified n8n creator?
Join the community
Complete MCP server exposing all Linear Tool operations to AI agents. Zero configuration needed - all 5 operations pre-built.
⚡ Quick Setup
  1. Import this workflow into your n8n instance
  2. Activate the workflow to start your MCP server
  3. Copy the webhook URL from the MCP trigger node
  4. Connect AI agents using the MCP URL
🔧 How it Works
MCP Trigger: Serves as your server endpoint for AI agent requests
Tool Nodes: Pre-configured for every Linear Tool operation
AI Expressions: Automatically populate parameters via $fromAI() placeholders
Native Integration: Uses official n8n Linear Tool tool with full error handling
📋 Available Operations (5 total)
Every possible Linear Tool operation is included:
🐛 Issue (5 operations)
Create an issue
Delete an issue
Get an issue
Get many issues
Update an issue
🤖 AI Integration
Parameter Handling: AI agents automatically provide values for:
• Resource IDs and identifiers
• Search queries and filters
• Content and data payloads
• Configuration options
Response Format: Native Linear Tool API responses with full data structure
Error Handling: Built-in n8n error management and retry logic
💡 Usage Examples
Connect this MCP server to any AI agent or workflow:
Claude Desktop: Add MCP server URL to configuration
Custom AI Apps: Use MCP URL as tool endpoint
Other n8n Workflows: Call MCP tools from any workflow
API Integration: Direct HTTP calls to MCP endpoints
✨ Benefits
Complete Coverage: Every Linear Tool operation available
Zero Setup: No parameter mapping or configuration needed
AI-Ready: Built-in $fromAI() expressions for all parameters
Production Ready: Native n8n error handling and logging
Extensible: Easily modify or add custom logic
🆓 Free for community use! Ready to deploy in under 2 minutes.
