Advanced retry and delay logic
Last update 15 days ago
Categories
Advanced Retry and Delay Logic
This template provides a robust solution for handling API rate limits and temporary service outages in n8n workflows. It overcomes the limitations of the default node retry settings, which cap retries at 5 and delays at 5 seconds. By using a custom loop with a Set, If, and Wait node, this workflow gives you complete control over the number of retries and the delay between them.
Instructions:
  1. Replace the placeholder HTTP Request node with your target node (the one that might fail).
  2. In the initial Set Fields node, modify the max_tries value to set the total number of attempts for your workflow.
  3. Adjust the delay_seconds value to define the initial delay between retries.
  4. Optionally, configure the Edit Fields node to implement exponential backoff by adjusting the delay_seconds expression (e.g., {{$json.delay_seconds * 2}}).
For a more detailed breakdown and tutorial of this template, you can find additional information here.
