Connect AI agents to EPA Clean Air Act data with MCP integration
Created by: David Ashby || cfomodz
David Ashby
Last update a month ago
Need help? Want access to this workflow + many more paid workflows + live Q&A sessions with a top verified n8n creator?
Join the community
Complete MCP server exposing 16 U.S. EPA Enforcement and Compliance History Online (ECHO) - Clean Air Act API operations to AI agents.
⚡ Quick Setup
  1. Import this workflow into your n8n instance
  2. Credentials Add U.S. EPA Enforcement and Compliance History Online (ECHO) - Clean Air Act credentials
  3. Activate the workflow to start your MCP server
  4. Copy the webhook URL from the MCP trigger node
  5. Connect AI agents using the MCP URL
🔧 How it Works
This workflow converts the U.S. EPA Enforcement and Compliance History Online (ECHO) - Clean Air Act API into an MCP-compatible interface for AI agents.
MCP Trigger: Serves as your server endpoint for AI agent requests
HTTP Request Nodes: Handle API calls to https://echodata.epa.gov/echo
AI Expressions: Automatically populate parameters via $fromAI() placeholders
Native Integration: Returns responses directly to the AI agent
📋 Available Operations (16 total)
🔧 Air_Rest_Services.Get_Download (2 endpoints)
GET /air_rest_services.get_download: Request Air Quality Data
POST /air_rest_services.get_download: Clean Air Act Download Data Service
🔧 Air_Rest_Services.Get_Facilities (2 endpoints)
GET /air_rest_services.get_facilities: Query Air Quality Facilities
POST /air_rest_services.get_facilities: Clean Air Act Facility Search
🔧 Air_Rest_Services.Get_Facility_Info (2 endpoints)
GET /air_rest_services.get_facility_info: Request Facility Details
POST /air_rest_services.get_facility_info: Clean Air Act Facility Enhanced Search
🔧 Air_Rest_Services.Get_Geojson (2 endpoints)
GET /air_rest_services.get_geojson: Request Air Quality GeoJSON
POST /air_rest_services.get_geojson: Clean Air Act GeoJSON Service
🔧 Air_Rest_Services.Get_Info_Clusters (2 endpoints)
GET /air_rest_services.get_info_clusters: Request Info Clusters Data
POST /air_rest_services.get_info_clusters: Clean Air Act Info Clusters Service
🔧 Air_Rest_Services.Get_Map (2 endpoints)
GET /air_rest_services.get_map: Request Air Quality Map
POST /air_rest_services.get_map: Clean Air Act Map Service
🔧 Air_Rest_Services.Get_Qid (2 endpoints)
GET /air_rest_services.get_qid: Query by Query ID
POST /air_rest_services.get_qid: Clean Air Act Search by Query ID
🔧 Air_Rest_Services.Metadata (2 endpoints)
GET /air_rest_services.metadata: Request Air Quality Metadata
POST /air_rest_services.metadata: Clean Air Act Metadata Service
🤖 AI Integration
Parameter Handling: AI agents automatically provide values for:
• Path parameters and identifiers
• Query parameters and filters
• Request body data
• Headers and authentication
Response Format: Native U.S. EPA Enforcement and Compliance History Online (ECHO) - Clean Air Act API responses with full data structure
Error Handling: Built-in n8n HTTP request error management
💡 Usage Examples
Connect this MCP server to any AI agent or workflow:
Claude Desktop: Add MCP server URL to configuration
Cursor: Add MCP server SSE URL to configuration
Custom AI Apps: Use MCP URL as tool endpoint
API Integration: Direct HTTP calls to MCP endpoints
✨ Benefits
Zero Setup: No parameter mapping or configuration needed
AI-Ready: Built-in $fromAI() expressions for all parameters
Production Ready: Native n8n HTTP request handling and logging
Extensible: Easily modify or add custom logic
🆓 Free for community use! Ready to deploy in under 2 minutes.
