Crypto alpha scanner with OpenAI - on-chain and social alerts to Telegram
Created by: Luka Zivkovic || zivkovic58
Luka Zivkovic
Last update a month ago
🎯 What This Does
This n8n workflow is a comprehensive crypto intelligence system that monitors multiple data sources simultaneously to identify alpha opportunities, whale movements, and emerging trends before they become mainstream.
It's like having a team of crypto analysts working 24/7 to spot the next big move.
Installment payment plan available on the link
⚡ Key Features
🐋 Whale Tracking: Monitor VIP wallets and smart money movements in real-time
📊 Multi-DEX Monitoring: Track price movements, volume, and buy pressure across DEXs
🆕 New Token Discovery: Catch tokens within 24 hours of launch
📱 Social Intelligence: Analyze Reddit sentiment and Twitter activity (optional)
🤖 AI-Powered Analysis: OpenAI summarizes and prioritizes signals by risk/opportunity
📨 Smart Telegram Alerts: Beautifully formatted alerts with actionable insights
🔄 Cross-Source Validation: Higher confidence through multiple data point correlation
🚀 What Makes This Special
Unlike basic price alerts, this system provides context and intelligence:
  • Early Alpha Detection: Spots whale accumulation before social discovery
  • Risk Assessment: AI categorizes signals by risk level (LOW/MEDIUM/HIGH/EXTREME)
  • Pattern Recognition: Detects exploits, new listings, partnerships, airdrops
  • Trend Scoring: Composite scores based on whale activity + social sentiment + DEX data
  • Smart Filtering: Only sends high-priority alerts to reduce noise
📈 Real-World Use Cases
For Traders
  • Get notified when whales start accumulating before price pumps
  • Spot new tokens with high whale interest and low social awareness
  • Receive exploit warnings to protect your investments
  • Track trending tokens with momentum building
For Researchers
  • Monitor smart money wallets and their strategies
  • Analyze correlation between whale movements and social sentiment
  • Track DeFi protocol updates and governance changes
  • Study market psychology through cross-source data
For Portfolio Managers
  • Early warning system for portfolio holdings
  • Discovery of emerging opportunities before mainstream adoption
  • Risk management through exploit and dump warnings
  • Market intelligence for strategic decision making
🛠️ Setup Requirements
Required (Free Tier Available)
  • Etherscan API (Free) - For whale transaction monitoring
  • Telegram Bot (Free) - For receiving alerts
  • OpenAI API (~$0.50-2/day) - For intelligent analysis
  • n8n Instance (Free self-hosted or cloud)
Optional Upgrades
  • Reddit OAuth (Free) - Improves social monitoring reliability
  • Twitter/Apify ($0.4 / 1K tweets) - Professional Twitter monitoring
🎛️ Configuration Options
Hot Tokens Monitoring
  • hotTokens: ['PEPE', 'WIF', 'BONK', 'JTO', 'PYTH', 'ARB', 'OP']
VIP Wallets (Smart Money)
  • vipWallets: [
    '0xae2Fc483527B8EF99EB5D9B44875F005ba1FaE13', // jaredfromsubway.eth
    '0x47ac0Fb4F2D84898e4D9E7b4DaB3C24507a6D503', // Binance 2
    // Add your own discovered alpha wallets
  • Sensitivity Thresholds
    thresholds: {
    whaleMove: 500000, // Minimum USD for whale alerts
    dexVolume: 100000, // Minimum volume to report
    priceChange1h: 10, // Percentage change threshold
    twitterEngagement: 100 // Minimum engagement for Twitter
📱 Sample Alert Output
🚨 CRYPTO ALPHA SCANNER
⏰ 14:30:25 UTC
💎 ALPHA OPPORTUNITIES 💎
🎯 $PEPE - Whale accumulation before social discovery
├─ 🐋 Whales: 5 buys / 1 sells (Accumulating)
├─ 💬 Social: 12 mentions (Bullish)
├─ 📊 Volume: $2,500k | Buy pressure: 73%
└─ 🔥 Patterns: whale_buying_new, pump_detected
📈 TRENDING TOKENS
🔥 $WIF (Score: 28)
├─ Whale: 🟢 Accumulating
├─ Social: 45 mentions (T:23 R:22)
├─ DEX: 68% buy pressure | $1,200k vol
└─ Change: +15.3% (24h)
📊 INTELLIGENCE SUMMARY
├─ Signals Analyzed: 23
├─ Tokens Tracked: 15
├─ Alpha Opportunities: 3
└─ High Priority: 8
🔧 Quick Start Guide
1️⃣ Basic Setup (10 minutes)
-- Get Etherscan API key (etherscan.io/apis)
-- Create Telegram bot (@BotFather)
-- Get OpenAI API key (platform.openai.com)
-- Import workflow into n8n
-- Configure credentials in each node
2️⃣ Customize Configuration
-- Edit "Load Configuration" node
-- Add your target tokens to hotTokens
-- Add whale wallets to vipWallets
-- Adjust thresholds for sensitivity
3️⃣ Test & Deploy
-- Execute workflow manually to test
-- Check Telegram for formatted alerts
-- Enable schedule trigger (runs every 30 minutes)
🎯 Who This Is For
✅ Perfect For:
  • Active Crypto Traders seeking early signals
  • DeFi Researchers tracking protocol developments
  • Whale Watchers following smart money
  • Alpha Hunters looking for pre-pump opportunities
  • Risk Managers needing exploit warnings
❌ Not Ideal For:
  • Complete crypto beginners
  • Set-and-forget investors
  • Those wanting guaranteed profits
🛡️ Risk Disclaimer
This tool provides information and analysis only. It does not guarantee profits and all crypto investments carry significant risk. The system is designed to help you make informed decisions, but you should:
  • Always do your own research (DYOR)
  • Never invest more than you can afford to lose
  • Understand that past performance doesn't predict future results
  • Be aware that whale movements can be deceptive
🆘 Support & Community
Support is available on the Discord channel
✅ Complete setup documentation
✅ Troubleshooting guide
✅ Configuration examples
📚Community Resources
💬 Discord community access
🔄 Regular workflow updates
💡 Strategy sharing with other users
Get Started Today
Transform your crypto trading with professional-grade intelligence. This system has been refined through months of testing and real-world usage.
Ready to spot the next alpha opportunity before everyone else?
N8N Link to get you started
