Festival social media automation with Gemini AI for X/Twitter & Facebook
Last update 23 days ago
🎉 Festival Social Media Automation with Gemini AI for X/Twitter & Facebook
Transform your festival marketing with this comprehensive automation workflow that creates and posts culturally authentic social media content across multiple platforms daily.
⚙️ What this workflow does
This workflow automatically:
  • Fetches festival data from Google Sheets based on today's date
  • Generates AI-powered prompts for both image creation and social media content
  • Creates stunning festival images using Google Gemini 2.0 Flash Preview
  • Produces platform-specific content optimized for X (Twitter) and Facebook
  • Posts automatically with proper image attachments and error handling
✨ Key Features
🎯 Intelligent Content Generation
  • AI-powered prompt generation tailored to each festival's cultural context
  • Platform-specific content optimization (character limits, hashtag strategies)
  • Culturally sensitive and authentic messaging
🎨 Visual Content Creation
  • Automated image generation using Google Gemini 2.0 Flash Preview
  • Festival-themed graphics with vibrant, culturally appropriate designs
  • Optimized for social media engagement
📲 Multi-Platform Publishing
  • Simultaneous posting to X (Twitter) and Facebook
  • Platform-specific formatting and optimization
  • Built-in error handling and backup posting methods
Fully Automated
  • Daily execution at 8:00 AM
  • Date-based festival data retrieval
  • Zero manual intervention required
📱 Apps and Integrations
  • Google Sheets - Festival calendar and data storage
  • Google Gemini 2.0 Flash Preview - AI content and image generation
  • X (Twitter) - Social media posting
  • Facebook Graph API - Facebook page posting
  • Schedule Trigger - Daily automation
🛠️🕊️ Setup Instructions
1. 📊 Google Sheets Configuration
  1. Create a Google Sheets document with columns: Date, Name of the Festival, Description
  2. Format dates as DD/MM/YYYY
  3. Connect your Google Sheets credential in n8n
2. 🤖 Google Gemini API Setup
  1. Obtain a Google AI Studio API key from Google AI Studio
  2. Configure the Google Gemini credential in n8n
  3. Ensure you have access to Gemini 2.0 Flash Preview
3. 🕊️X (Twitter) Credentials Setup
Important: Due to X API limitations, you'll need TWO separate OAuth2 credentials: X API
For Image Upload (Generic OAuth2):
  1. Create a new OAuth2 credential with these settings:
    • Grant Type: PKCE
    • Authorization URL: https://x.com/i/oauth2/authorize
    • Access Token URL: https://api.x.com/2/oauth2/token
    • Scope: media.write offline.access tweet.read users.read
    • Note: Cannot combine media.write with tweet.write in the same credential
For Tweet Posting (X OAuth2):
  1. Use the predefined X OAuth2 credential
  2. Configure with scopes: tweet.write offline.access tweet.read users.read
4. 📘Facebook Graph API Setup
  1. Create a Facebook App and get your access token from Meta for Developers
  2. Configure the Facebook Graph API credential
  3. Update the node with your Facebook page ID
🎬 How to Use
  1. Populate your Google Sheets with festival data for upcoming dates
  2. Activate the workflow - it will run automatically daily at 8:00 AM
  3. Monitor the execution - check logs for successful posts or any errors
  4. Customize content by modifying the prompt generation logic if needed
🔄 Workflow Components
🔗 Data Flow
  1. Daily TriggerGet Today's DateFetch Festival Data
  2. Generate AI PromptsCreate Image & Content
  3. Process MediaMerge DataPost to Platforms
🛡️ Error Handling
  • Backup HTTP posting method for X if primary method fails
  • Continue execution even if individual platform posting fails
  • Comprehensive error logging for troubleshooting
🎨 Customization Options
✍️ Content Personalization
  • Modify the prompt generation logic for different content styles
  • Adjust platform-specific character limits and hashtag strategies
  • Customize image generation prompts for different visual styles
🌐 Platform Extension
  • Add Instagram, LinkedIn, or other social media platforms
  • Implement additional content formats (Stories, Reels, etc.)
  • Create platform-specific posting schedules
📊 Data Sources
  • Connect to different data sources (Airtable, Notion, CMS)
  • Add support for multiple festival categories
  • Implement content approval workflows
💡 Best Practices
📝 Content Quality
  • Regularly review and update your festival database
  • Monitor AI-generated content for cultural sensitivity
  • Test different prompt styles for optimal engagement
🔑 API Management
  • Monitor API usage limits for all connected services
  • Implement rate limiting for high-volume posting
  • Set up alerts for credential expiration
⏰ Scheduling
  • Consider time zones for optimal posting times
  • Implement staggered posting across platforms
  • Add weekend/holiday scheduling logic
🔧 Troubleshooting
⚠️ Common Issues
  • Image upload fails: Check OAuth2 credentials and API limits
  • Content generation errors: Verify Gemini API key and model availability
  • Date matching issues: Ensure date format consistency in Google Sheets
⚡️ Performance Tips
  • Optimize image generation prompts for faster processing
  • Use structured output parsing for consistent results
  • Implement content caching for repeated festivals
🎯 Use Cases
  • Cultural Organizations - Automate festival announcements and celebrations
  • Event Management Companies - Scale social media presence across multiple events
  • Tourism Boards - Promote local festivals and cultural events
  • Marketing Agencies - Manage multiple client festival campaigns
  • Community Organizations - Engage audiences with regular cultural content
⭐️ Benefits
  • Time Savings - Eliminate manual social media posting
  • Consistency - Maintain regular posting schedule
  • Cultural Authenticity - AI-generated content respects cultural context
  • Multi-Platform Reach - Simultaneous posting increases visibility
  • Scalability - Handle unlimited festivals with zero additional effort
    This workflow transforms festival marketing from a time-consuming manual process into a fully automated, culturally intelligent system that engages audiences across multiple platforms while maintaining authenticity and relevance.
