Sync Zendesk knowledge base articles to Airtable with markdown conversion
Created by: Agent Studio || agentstudio
Agent Studio
Last update 25 days ago
Who is it for
  • Customer service or support teams who want to use their Zendesk articles in other tools.
  • Content/Knowledge managers consolidating or migrating knowledge bases.
  • Ops/automation specialists who want Markdown versions of articles (could be adapted to Notion, Google Sheets, or any Markdown-friendly system).
How to get started
  • Download the template and install it on your instance
  • Set Zendesk and Airtable credentials
  • Modify the Zendesk base_url and Airtable's table and base
  • Run the workflow once manually to get your existing articles
  • Finally, modify the Schedule Trigger (by default it runs every 30 days) and activate the workflow
Prerequisites
  • Airtable base set up using this template. It includes the fields Title, Content, URL and Article ID.
  • Zendesk account with API access (read permissions for help center articles)
  • Zendesk API credentials (see instructions below)
  • Airtable API credentials (see instructions below)
Getting Your Credentials
Airtable:
  1. Sign up or log in to Airtable.
  2. Go to your account settings and generate a Personal Access Token (recommended scopes: data.records:read, data.records:write).
  3. In n8n, create new Airtable credentials using this token.
Zendesk:
  1. Log in to your Zendesk dashboard.
  2. Go to Admin Center > Apps and Integrations > Zendesk API.
  3. Enable “Token Access,” and create an API token.
  4. In n8n, add Zendesk credentials with your Zendesk domain, email, and the API token.
1. Triggers
  • Manual: For first setup, use the Manual Trigger to fetch all existing articles.
  • Scheduled: Automatically runs every N days to fetch only new or updated articles since the last run.
2. Fetch Articles from Zendesk
  • Calls the Zendesk Help Center API, using pagination to handle large volumes.
3. Extract and Prepare Data
  • Splits out each article, then collects fields: id, url, title, and body.
  • Converts the article body from HTML to Markdown (for portability and easier reuse).
4. Upsert Into Airtable
  • Inserts new articles, or updates existing ones (using Article ID as the unique key).
  • Fields stored: Title, Content (Markdown), URL, Article ID.
Airtable Template
  • Use this Airtable template as your starting point.
  • Make sure the table has columns: Title, Content, URL, Article ID. You can add more depending on your needs.
Example Use Cases
  • Migrating Zendesk articles to another knowledge base.
  • Building an internal knowledge hub in Airtable or Notion.
  • Creating Markdown backups for compliance or versioning.
Service
If you need help implementing the template or modifying it, just reach out 💌
