Create Bilingual Newsletters with GPT-4o, AI Images & Videos for HubSpot & SharePoint
Created by: plemeo || plemeo
plemeo
Last update 5 hours ago
Who’s it for
Marketing, growth, and automation teams that need to ship polished bilingual newsletters—complete with images, optional video, and multi-channel distribution—without writing a line of code.
How it works / What it does
  1. A Webhook receives a plain-language request (e.g. “Create a newsletter about XYZ and store it in SharePoint”). The Webhook can be changed to another trigger, fr example Manual Trigger.
  2. An AI Agent (OpenAI GPT-4o) drafts German & English newsletter copy following a strict JSON schema.
  3. SharePoint fetches an HTML template; a Code node injects AI copy into the placeholders.
  4. Optional creative assets:
    • Pollinations AI → image (resolution check & frame overlay)
    • FAL AI → short video + Lyria2 audio → merged via FFmpeg API
  5. A Gmail Approval step sends the draft to an approver; the flow continues only on “Approve”.
  6. Depending on user intent the workflow:
    • Emails the newsletter to HubSpot contacts, and/or
    • Saves HTML (+ JPG/Video URL) to a SharePoint library.
How to set up
  1. Import the template
  2. Open the yellow sticky note and follow the checklist
    • Create credentials for OpenAI, HubSpot (App Token), Microsoft 365, Gmail, and FAL AI.
    • Enter them in n8n Credential Manager (never in the HTTP node).
  3. Edit the Configuration Settings Set node with your ENV_* variables.
  4. Activate the workflow, copy the production Webhook URL, and trigger it with JSON body { "text": "…" } or with a desired trigger.
Requirements
  • OpenAI account
  • Microsoft 365 tenant (SharePoint & Outlook)
  • HubSpot App Token
  • FAL AI API Key (video & audio generation)
How to customize
  • Want a different language? Tweak the AI prompt inside AI Agent.
  • Want a different storage provider? Change the SharePoint nodes to Google Drive or Dropbox.
  • Skip video generation: set include_video to false in the incoming prompt.
  • Change the distribution logic by adjusting the WF Result Switch node.
  • Add more channels (e.g. Slack) by inserting additional branches after the Switch and modifying the intent determination at the beginning of the workflow.
