Auto-bidder for Freelancer.com with Telegram approval and AI proposals
Last update 7 months ago
🔁 Auto-Bidder for Freelancer.com with Telegram Approval and AI Proposals
This n8n template automates your freelance bidding workflow on Freelancer.com, combining API calls, Telegram interactions, and AI-generated proposals. Ideal for freelancers who want to bid smarter, faster, and hands-free.
✨ Features
  • 🔍 Skill-Based Project Search
    Searches for active projects on Freelancer.com using your chosen skill keywords (e.g., n8n, Python, Django).
  • 🚫 Duplicate Bid Prevention
    Automatically checks if you’ve already bid on a project and skips it.
  • 🤖 AI Proposal Generation
    Generates short, persuasive, and customized proposals using an AI agent.
  • 📬 Telegram Notifications
    Sends project summaries to Telegram with inline buttons to Bid or Cancel.
  • Auto-Bid Submission
    When you approve a project via Telegram, the bid is submitted with predefined values (amount, period, milestone).
  • ⏱️ Manual or Scheduled Execution
    Supports both on-demand and scheduled workflows (hourly, daily, etc.).
📌 Requirements
  • Freelancer.com API token (OAuth)
  • Telegram Bot API token
  • OpenAI API key (for proposal generation)
📎 Use Cases
  • Freelancers automating repetitive bidding tasks
  • Agencies managing client profiles
  • Developers experimenting with AI + API + chat integration
🔗 Included Workflows
  • freelancerMain – Kicks off execution with skill input
  • freelancerAgent – Performs project search, bidding logic, Telegram prompts, and AI proposal generation
💡 Tip: You can easily customize the skill query list, bid amount logic, or prompt format in the workflow settings.
