Automate outbound voice calls from Go High Level opportunities with Vapi
Created by: Aitor | 1Node || aitoralonso
Aitor | 1Node
Last update a month ago
This workflow triggers when a new opportunity is created in Go High Level (GHL), fetches the associated contact details, and initiates an outbound call using Vapi. The call is made by a Vapi assistant configured with the appropriate credentials.
🧾 Requirements
Go High Level (GHL)
  • A Go High Level account
  • GHL developer private app and credentials enabled in n8n
  • Webhook URL from n8n added to your GHL private app
Vapi
  • A Vapi account with credit
  • A connected phone number to make calls
  • An assistant created and ready to make calls
  • Your Vapi API key
🔗 Useful Links
🔄 Workflow Breakdown
1. Trigger: GHL Opportunity Created
  • Triggered by a Webhook (POST) from Go High Level when a new opportunity is created.
  • Webhook URL must be enabled in your GHL private app.
2. Get a GHL Contact
  • Retrieves contact details from GHL CRM using the contact ID from the opportunity.
  • Includes information such as phone number, name, and custom fields.
3. Wait 5 Minutes
  • Introduces a short delay before making the call to avoid immediate outreach.
  • Helps ensure data is synced and gives the system time for any follow-up automation.
4. Set Vapi Fields (Manual Step)
  • Set the required fields for the Vapi API call:
    • vapiPhoneNumberId – the number id making the call
    • vapiAssistantId – the assistant who will handle the call
    • vapiApi – your secure Vapi API key
5. Start Outbound Vapi Call
  • Sends a POST request to https://api.vapi.ai/call
  • Payload includes:
    • Contact’s phone number
    • Selected Vapi assistant
    • Vapi phone number id to start the call
✅ Summary
This n8n automation connects your CRM (Go High Level) with voice automation (Vapi) to immediately respond to new opportunities. Once a lead is created, they will receive a personalized voice call from a Vapi AI assistant.
🙋‍♂️ Need Help?
Feel free to contact us at 1 Node
Get instant access to a library of free resources we created.
