Automate multi-bank transaction sync & reporting with GoCardless & Maybe Finance
Last update 25 days ago
Categories
🏦 GoCardless ⇄ Maybe Finance — Automatic Multi-Bank Sync & Weekly Overview 💸
Who’s it for 🤔
Freelancers, founders, households, and side-hustlers who work with several bank accounts but want one, always-up-to-date budget inside Maybe Finance—no more CSV exports or copy-paste.
How it works / What it does ⚙️
  1. Schedule Trigger (cron) fires every Monday 📅
    (switch to Manual Trigger while testing)
  2. Get access token — fresh 24 h GoCardless token 🔑
  3. Fetch transactions for each account:
    • Revolut Pro
    • Revolut Personal
    • ABN AMRO
      (add extra HTTP Request nodes for any other GoCardless-supported banks)
  4. Extract booked — keep only settled items 🗂️
  5. Set transactions … — map every record to Maybe Finance’s schema 📝
  6. Merge all arrays into one payload 🔄
  7. Create transactions to Maybe — POSTs each item via API 🚀
  8. Resend Email — sends you a “Weekly transactions overview” 📧
All done in a single run — your Maybe dashboard is refreshed and you get an inbox alert.
How to set up 🛠️
  1. Import the template into n8n (cloud or self-hosted).
  2. Create credentials
    • GoCardless secret_id & secret_key
    • Maybe Finance API key
    • (Optional) Resend API key for email notifications
  3. One-time GoCardless config (run the blocks on the left):
    1. /token/new/ → obtain token
    2. /institutions → find institution IDs
    3. /agreements/enduser/ → create agreements
    4. /requisitions/ → get the consent URL & finish bank login
    5. /requisitions/{id} → copy the GoCardless account_ids
  4. Create the same accounts in Maybe Finance and run the HTTP GET request in the purple frame and copy their account_ids.
  5. Open each Set transactions … node and paste the correct Maybe account_id.
  6. Adjust the Schedule Trigger (e.g. daily, monthly).
  7. Save & activate 🎉
Requirements 📋
  • n8n 1.33 +
  • GoCardless app (secret ID & key, live or sandbox)
  • Maybe Finance account & API key
  • (Optional) Resend account for email
How to customize ✨
  • Include pending transactions: change the Item Lists filter.
  • Add more banks: duplicate the “Get … transactions” → “Extract booked” → “Set transactions” path and plug its output into the Merge node.
  • Different interval: edit the cron rule in Schedule Trigger.
  • Disable emails: just remove or deactivate the Resend node.
  • Send alerts to Slack / Teams: branch after the Merge node and add a chat node.
Happy budgeting! 💰
