Create marketing content with voice commands using GPT-4 & AI tools in Telegram
Created by: Muhammad Ashar || ashar0086
Muhammad Ashar
Last update 12 days ago
How It Works – Your AI Marketing Team in Action
This automation acts as your AI-powered content and image marketing assistant inside Telegram. With just a voice note or text message, it can:
🧠 Understand your request
– Whether you send a message or speak into Telegram, it transcribes and processes your input using GPT-4.
🎨 Create and edit content
– Based on what you say, it can generate:
✍️ Blog posts
💼 LinkedIn posts
🎬 Faceless videos
🖼️ AI-generated images
🪄 Edits to existing images
🔎 Searches through your image database
💬 Replies directly in Telegram
– It sends you back the result—whether that’s a post, image, or video link—without leaving the app.
🧩 Built using LangChain agent logic
– It intelligently chooses the right tool from a suite of sub-workflows like "Create Image", "Blog Post", or "Video" using agent reasoning.
🛠️ Setup Steps – Get Started in Minutes!
⌛ Time Estimate: ~15–30 minutes (faster if you're familiar with n8n)
🔗 1. Import the Template Pack
📥 Download and install these workflows into your n8n:
Create Image, Edit Image, Search Images
Blog Post, LinkedIn Post, Video
🔐 2. Add Required Credentials
Telegram Bot 🤖
OpenRouter AI 🧠
Tavily API (for smart research) 📚
ElevenLabs 🎙️ (for voice in videos)
PiAPI & Runway 🎞️ (for faceless videos)
🧩 3. Link the Tools to the Agent Node
– Make sure the "Marketing Team Agent" is connected to each of the content creation tools as shown in the workflow.
📎 4. Download Templates & Logs
🧾 Google Sheets Log Template (to track output)
🖼️ Creatomate Template (optional for enhanced image control – shared in Skool group)
📌 Pro Tip: All detailed step-by-step setup instructions are included as sticky notes inside the n8n canvas. Just follow along!
