CYBERPULSE AI BlueOps: asset enrichment engine
Created by: Adnan Tariq || adnantariq
Adnan Tariq
Last update a month ago
Categories
👤 Who it’s for
Blue teamers, SOC operators, cyber analysts, and SME defenders who want to automatically enrich daily CVE/IOC threats by matching them to their internal asset database.
Ideal for compliance-driven teams (NIST CSF, Essential Eight) seeking automated enrichment and alert routing.
⚙️ How it works / What it does
Loads current threat data from Sheet or Module 1 output
Loads internal asset database from Google Sheets
Merges based on matching IP fields
Calculates impact score (threat score × asset value)
Applies basic playbook logic to classify action
Sends summary emails for matched threats
Logs to archived and live threat monitoring sheets
Built with modular, no-code logic and alerting support
🛠️ How to set up
Google Sheets:
Authenticate your Google account
(OAuth2) and set your Asset DB and Threats log sheet IDs.
Email:
Add sender/recipient addresses and SMTP credentials.
Customize Matching Logic:
Adjust enrichment rule in the “🧠 Match Threats to Assets” node.
Triggers:
Add a Cron node or Webhook to schedule the enrichment job.
Review sticky notes:
All steps are explained clearly within the workflow nodes.
📋 Requirements
Google Sheets with asset inventory + threat log
Google account with Sheets API access
SMTP service (Gmail, Mailgun, SendGrid, etc.)
Optional: OpenAI for dynamic playbook scoring (if extending logic)
🧩 How to customize the workflow
Replace Google Sheets with Supabase, Airtable, or Postgres
Extend enrichment rule to include hostname or UUID matching
Fine-tune scoring logic by severity, CVSS, or business unit
Route alerts via Slack, Discord, or n8n Webhook endpoints
Add conditional routing for alert suppression or review queues
📦 No sensitive data included. All credentials and sheet IDs are placeholders.
🔐 This module is part of the CYBERPULSEBlueOps Pro Pack.
For full access to advanced Blue Team automations, visit cyberpulsesolutions.com/blueops
