Generate dynamic sales pipeline metrics for Slack using Airtable
Created by: James Carter || arioloop
James Carter
Last update 13 days ago
Categories
This n8n template generates a dynamic weekly sales report from Airtable and sends it to Slack. It calculates key sales metrics like total pipeline value, weighted pipeline (based on deal stage), top deal, closed revenue, and win rate.. all formatted in a clean Slack message.
A schedule trigger starts the workflow (e.g., every Monday). It fetches deal data from Airtable, splits open vs closed deals, calculates all metrics with JavaScript, and formats the output. The message is then sent to Slack using Markdown for readability.
How to use
Update the Airtable credentials and select your base and table with fields:
  • Deal Name, Value, Status, etc.
    Set the Slack channel in the final node to your preferred sales or ops channel.
Requirements
  • Airtable base with relevant deal data (see field structure)
  • Slack webhook or token for sending messages
Customising this workflow
You can adapt the logic to other CRMs like Salesforce or HubSpot, add charts, or tweak stage weights. You can also change the schedule or add filters (e.g., by rep or region).
