AI-powered corporate research system for animal advocacy campaigns with Claude & Gemini
Created by: Open Paws || openpaws
Open Paws
Last update 22 days ago
Who’s it for 🎯
This workflow is designed for animal advocacy campaigners, strategists, and researchers who need detailed intelligence on corporate targets and their key stakeholders like executives, investors, and suppliers.
How it works / What it does ⚙️
It uses the Multi-tool Research Agent subworkflow to research a target company, extract relevant sub-targets, and then runs focused research on each sub-target. It compiles all findings into a detailed HTML report outlining tailored campaign tactics.
How to set up 🛠️
  1. Import this workflow and the Multi-tool Research Agent subworkflow.
  2. Configure API credentials in n8n.
  3. Set the target company and campaign details.
  4. Test the workflow to verify multi-level research and report generation.
Requirements 📋
  • n8n instance with internet access
  • Valid API keys
  • The Multi-tool Research Agent subworkflow installed and linked
  • Optional email node for sending reports
How to customize 🔧
  • Modify target inputs and sub-target extraction for different industries.
  • Adjust research prompts in the subworkflow for style or focus.
  • Customize the HTML report template for branding.
  • Attach an email node to send reports automatically or route output as needed.
  • Add error handling or branching for campaign specifics.
Use this template to generate strategic, research-driven campaigns with actionable intelligence on complex corporate targets.
