Automate content analysis & multi-platform distribution with GPT-4
Last update a month ago
How It Works ⚙️
This workflow is a comprehensive, AI-powered system that acts as a virtual content manager for creators and marketing teams. It automates the entire content lifecycle, from ingestion and analysis to multi-channel distribution and performance logging.
  1. Multi-Source Ingestion: The workflow starts by ingesting new content from a trigger, such as a WordPress blog post or an RSS Feed from a YouTube channel.
  2. AI-Powered Analysis: The new content is sent to an OpenAI (GPT-4) node, which performs a series of high-value tasks. It instantly creates a summary, extracts keywords, analyzes the sentiment, and generates tailored post drafts for different social media platforms.
  3. Smart Distribution: A Buffer node then takes these AI-generated, platform-specific posts and schedules them for optimal times across your social media channels like Twitter, LinkedIn, and Facebook.
  4. Centralized Archiving: All of the content data, including the AI-generated summaries and insights, are automatically logged into a Google Sheets database. This creates a powerful, searchable archive and an analytics dashboard for tracking content performance.
How to Set Up 🛠️
  1. Import the Workflow: Copy the provided workflow JSON and import it into your n8n instance.
  2. Configure Credentials:
    • OpenAI: Add your API Key.
    • WordPress: Add your API credentials.
    • Buffer: Add your API credentials.
    • Google Sheets: Add your OAuth2 credentials.
  3. Customize Workflow Nodes:
    • Node 1 (WordPress Trigger): Select your WordPress credential. You can also add other trigger nodes like RSS Feed Read Trigger if needed.
    • Node 2 (OpenAI): You can customize the prompt to get different kinds of output or translate into more languages.
    • Node 4 (Buffer): Select the social media profiles you want to post to.
    • Node 5 (Google Sheets): Replace the placeholder [YOUR SPREADSHEET ID] and [YOUR CONTENT LOG SHEET NAME] with your own details and map the data columns.
  4. Save & Activate: Once all settings and credentials are configured, save the workflow and click the "Inactive" toggle in the top-right corner to make it live.
