Monitor commercial real estate opportunities from LoopNet with ScrapeGraphAI & Telegram
Created by: vinci-king-01 || vinci-king-01
vinci-king-01
Last update a month ago
This workflow automatically scrapes commercial real estate listings from LoopNet and sends opportunity alerts to Telegram while logging data to Google Sheets.
Key Steps
  1. Scheduled Trigger - Runs every 24 hours to collect fresh CRE market data
  2. AI-Powered Scraping - Uses ScrapeGraphAI to extract property information from LoopNet
  3. Market Analysis - Analyzes listings for opportunities and generates market insights
  4. Smart Notifications - Sends Telegram alerts only when investment opportunities are found
  5. Data Logging - Stores daily market metrics in Google Sheets for trend analysis
Set up steps
Setup time: 10-15 minutes
  1. Configure ScrapeGraphAI credentials - Add your ScrapeGraphAI API key for web scraping
  2. Set up Telegram connection - Connect your Telegram bot and specify the target channel
  3. Configure Google Sheets - Set up Google Sheets integration for data logging
  4. Customize the LoopNet URL - Update the URL to target specific CRE markets or property types
  5. Adjust schedule - Modify the trigger timing based on your market monitoring needs
Keep detailed configuration notes in sticky notes inside your workflow
