Stock market technical analysis alerts with Alpha Vantage & Discord
Created by: Raz Hadas || raz-hadas
Raz Hadas
Last update a month ago
Categories
This n8n template demonstrates how to automate stock market technical analysis to detect key trading signals and send real-time alerts to Discord. It's built to monitor for the Golden Cross (a bullish signal) and the Death Cross (a bearish signal) using simple moving averages.
Use cases are many: Automate your personal trading strategy, monitor a portfolio for significant trend changes, or provide automated analysis highlights for a trading community or client group.
💡 Good to know
  • This template relies on the Alpha Vantage API, which has a free tier with usage limits (e.g., API calls per minute and per day). Be mindful of these limits, especially if monitoring many tickers.
  • The data provided by free APIs may have a slight delay and is intended for informational and analysis purposes.
  • Disclaimer: This workflow is an informational tool and does not constitute financial advice. Always do your own research before making any investment decisions.
⚙️ How it works
  • The workflow triggers automatically every weekday at 5 PM, after the typical market close.
  • It fetches a list of user-defined stock tickers from the Set node.
  • For each stock, it gets the latest daily price data from Alpha Vantage via an HTTP Request and stores the new data in a PostgreSQL database to maintain a history.
  • The workflow then queries the database for the last 121 days of data for each stock.
  • A Code node calculates two Simple Moving Averages (SMAs): a short-term (60-day) and a long-term (120-day) average for both today and the previous day.
  • Using If nodes, it compares the SMAs to see if a Golden Cross (short-term crosses above long-term) or a Death Cross (short-term crosses below long-term) has just occurred.
  • Finally, a formatted alert message is sent to a specified Discord channel via a webhook.
🚀 How to use
  • Configure your credentials for PostgreSQL and select them in the two database nodes.
  • Get a free Alpha Vantage API Key and add it to the "Fetch Daily History" node. For best practice, create a Header Auth credential for it.
  • Paste your Discord Webhook URL into the final "HTTP Request" node.
  • Update the list of stock symbols in the "Set - Ticker List" node to monitor the assets you care about.
  • The workflow is set to run on a schedule, but you can press "Test workflow" to trigger it manually at any time.
✅ Requirements
  • An Alpha Vantage account for an API key.
  • A PostgreSQL database to store historical price data.
  • A Discord account and a server where you can create a webhook.
🎨 Customising this workflow
  • Easily change the moving average periods (e.g., from 60/120 to 50/200) by adjusting the SMA_SHORT and SMA_LONG variables in the "Compute 60/120 SMAs" Code node.
  • Modify the alert messages in the "Set - Golden Cross Msg" and "Set - Death Cross Msg" nodes.
  • Swap out Discord for another notification service like Slack or Telegram by replacing the final HTTP Request node.
