Analyze images, videos, documents & audio with Gemini Tools and Qwen LLM Agent
Created by: Mauricio Perera || rckflr
Mauricio Perera
Last update 13 days ago
📁 Analyze uploaded images, videos, audio, and documents with specialized tools — powered by a lightweight language-only agent.
🧭 What It Does
This workflow enables multimodal file analysis using Google Gemini tools connected to a text-only LLM agent. Users can upload images, videos, audio files, or documents via a chat interface. The workflow will:
  • Upload each file to Google Gemini and obtain an accessible URL.
  • Dynamically generate contextual prompts based on the file(s) and user message.
  • Allow the agent to invoke Gemini tools for specific media types as needed.
  • Return a concise, helpful response based on the analysis.
🚀 Use Cases
  • Customer support: Let users upload screenshots, documents, or recordings and get helpful insights or summaries.
  • Multimedia QA: Review visual, audio, or video content for correctness or compliance.
  • Educational agents: Interpret content from PDFs, diagrams, or audio recordings on the fly.
  • Low-cost multimodal assistants: Achieve multimodal functionality without relying on large vision-language models.
🎯 Why This Architecture Matters
Unlike end-to-end multimodal LLMs (like Gemini 1.5 or GPT-4o), this template:
  • Uses a text-only LLM (Qwen 32B via Groq) for reasoning.
  • Delegates media analysis to specialized Gemini tools.
✅ Advantages
Feature Benefit
🧩 Modular LLM + Tools are decoupled; can update them independently
💸 Cost-Efficient No need to pay for full multimodal models; only use tools when needed
🔧 Tool-based Reasoning Agent invokes tools on demand, just like OpenAI’s Toolformer setup
⚡ Fast Groq LLMs offer ultra-fast responses with low latency
📚 Memory Includes context buffer for multi-turn chats (15 messages)
🧪 How It Works
🔹 Input via Chat
  • Users submit a message and (optionally) files via the chatTrigger.
🔹 File Handling
  • If no files: prompt is passed directly to the agent.
  • If files are included:
    • Files are split, uploaded to Gemini (to get public URLs).
    • Metadata (name, type, URL) is collected and embedded into the prompt.
🔹 Prompt Construction
  • A new chatInput is dynamically generated:
    User message
    Media: [array of file data]
🔹 Agent Reasoning
  • The Langchain Agent receives:
    • The enriched prompt
    • File URLs
    • Memory context (15 turns)
    • Access to 4 Gemini tools:
      • IMG: analyze image
      • VIDEO: analyze video
      • AUDIO: analyze audio
      • DOCUMENT: analyze document
The agent autonomously decides whether and how to use tools, then responds with concise output.
🧱 Nodes & Services
Category Node / Tool Purpose
Chat Input chatTrigger User interface with file support
File Processing splitOut, splitInBatches Process each uploaded file
Upload googleGemini Uploads each file to Gemini, gets URL
Metadata set, aggregate Builds structured file info
AI Agent Langchain Agent Receives context + file data
Tools googleGeminiTool Analyze media with Gemini
LLM lmChatGroq (Qwen 32B) Text reasoning, high-speed
Memory memoryBufferWindow Maintains session context
⚙️ Setup Instructions
1. 🔑 Required Credentials
  • Groq API key (for Qwen 32B model)
  • Google Gemini API key (Palm / Gemini 1.5 tools)
2. 🧩 Nodes That Need Setup
  • Replace existing credentials on:
    • Upload a file
    • Each GeminiTool (IMG, VIDEO, AUDIO, DOCUMENT)
    • lmChatGroq
3. ⚠️ File Size & Format Considerations
  • Some Gemini tools have file size or format restrictions.
  • You may add validation nodes before uploading if needed.
🛠️ Optional Improvements
  • Add logging and error handling (e.g., for upload failures).
  • Add MIME-type filtering to choose the right tool explicitly.
  • Extend to include OCR or transcription services pre-analysis.
  • Integrate with Slack, Telegram, or WhatsApp for chat delivery.
🧪 Example Use Case
"Hola, ¿qué dice este PDF?"
Uploads a document → Agent routes it to Gemini DOCUMENT tool → Receives extracted content → LLM summarizes it in Spanish.
🧰 Tags
multimodal, agent, langchain, groq, gemini, image analysis, audio analysis, document parsing, video analysis, file uploader, chat assistant, LLM tools, memory, AI tools
📂 Files
  • This template is ready to use as-is in n8n.
  • No external webhooks or integrations required.
