AI-powered cold call machine with LinkedIn, OpenAI & Sales Navigator
Created by: Matthieu || yaznow
Matthieu
Last update 2 days ago
🔧 AI-Powered Cold Call Machine
🎯 Purpose
The AI-Powered Cold Call Machine is a fully automated workflow designed to generate qualified leads from LinkedIn, evaluate them using AI-based scoring, identify key decision-makers, and generate personalized cold call scripts. All results are saved to a Google Sheet-based CRM.
⚙️ How It Works
1. Initialization
  • Triggered either manually or via schedule.
  • Pulls configuration from a Google Sheet’s Settings tab (e.g., target product, keywords, company size, API key).
2. Company Search on LinkedIn
  • Uses the Ghost Genius API to search for companies based on cleaned, relevant keywords extracted by OpenAI.
  • Handles pagination, up to 1000 companies per batch.
3. Company Filtering
Each company goes through:
  • Data enrichment via Ghost Genius (website, size, followers, etc.).
  • Filtering:
    • Must have a LinkedIn page with a website.
    • Must have 200+ followers.
  • Deduplication: checks if the company already exists in the CRM.
4. AI-Based Company Scoring
  • A specialized AI model scores each company from 0 to 10 based on:
    • Industry fit.
    • Size/location alignment.
    • Potential pain points that match your offering.
  • If the company is new and relevant (score ≥ 7), it is saved in the Companies sheet.
5. Decision Maker Identification
  • Uses Sales Navigator API (via Ghost Genius) to find employees with targeted job titles.
  • For each matching profile:
    • Enriches contact data (title, bio, etc.).
    • Retrieves phone number (if available).
    • Generates a 20-second personalized cold call script using OpenAI, based on company and profile data.
    • Saves all information in the Leads tab of the CRM.
  • If no decision maker is found, the company status is marked accordingly.
📈 Outcome
  • A fully enriched, qualified lead database.
  • Custom cold call scripts ready to be used by SDRs or founders.
  • Zero manual work – from search to lead generation, everything is automated.
💡 Use Case
Perfect for SDRs, founders, or growth marketers looking to scale cold outreach without sacrificing personalization or running into LinkedIn scraping limits.
