LinkedIn lead generation with GPT-4o, Apify scraping, and automated outreach
Created by: Basil Irfan || basil
Basil Irfan
Last update a month ago
🚀 LinkedIn Lead-Gen Flywheel – Apify → GPT-4o → Google Sheets → Phantombuster
What this workflow does
  1. Collect audience specs – simple web-form asks for your ideal company profile.
  2. Generate a laser-targeted Apollo search URL with GPT-4o (no manual filtering).
  3. Scrape the matching leads via an Apify actor (returns clean JSON).
  4. Craft hyper-personalized icebreakers for each lead using GPT-4o (ultra-short, human-sounding).
  5. Log everything to Google Sheets – name, LinkedIn URL, company site, summary, and the icebreaker.
  6. (Optional) Auto-launch Phantombuster to fire off those connection requests at scale.
Why it matters
  • Zero grunt work: audience research, scraping, copy-writing, and outreach all run hands-free.
  • Punchy personalization: micro-icebreakers outperform canned intros, boosting accept rates.
  • Scales with you: flip a switch to go from 10 to 1 000+ connections/day.
Node rundown
Step Node Key Inputs Key Outputs
1 Form Trigger Audience description description_of_company
2 OpenAI (GPT-4o) Audience text SearchUrl
3 HTTP Request – Apify SearchUrl, APIFY_TOKEN Lead JSON
4 OpenAI (GPT-4o) Lead JSON Icebreaker
5 Google Sheets Lead + Icebreaker Row append/update
6 Aggregate Sheet rows Batched output
7 HTTP Request – Phantombuster PHANTOM_KEY, AGENT_ID Launch status
Prerequisites
  • OpenAI API key (GPT-4o access recommended)
  • Apify API token with access to actor id
  • Google Service Account creds shared with your target sheet
  • Phantombuster API key and Agent ID for your LinkedIn connector
  • Active Apollo account to open the generated search URL (only required for debugging)
Setup (5-minute sprint)
  1. Import the workflow into n8n.
  2. Add the required credentials in CredentialsOpenAI, Apify, Google Sheets, Phantombuster.
  3. Paste your Phantombuster Agent ID into the HTTP Request node URL.
  4. Publish the Form Trigger URL—this is where you (or your SDRs) describe the target audience.
  5. Hit Execute Workflow once to verify data flows end-to-end.
Customization tips
  • Titles & keywords: tweak the prompt in the first GPT-4o node to lock in different roles or industries.
  • Icebreaker style: adjust the second GPT-4o prompt to match your brand voice.
  • Data columns: map extra fields from Apify into Google Sheets as needed.
  • Skip outreach: disable the Phantombuster node if you only want the leads + icebreakers.
