Classify emails and send replies with GPT-4o and gotoHuman for supervision
Created by: gotoHuman || gotohuman
gotoHuman
Last update a month ago
Let AI classify your incoming emails and draft replies.
Use gotoHuman to approve emails before they are sent out. It also lets you manually edit the draft or even ask for a retry.
  1. The workflow is triggered for each new email which gets passed to an AI classification agent.
    It assigns the email to one of the categories defined in the prompt (Customer Support, Sales opportunity, Promo, Personal,...). The agent also determines whether a reply is needed and if it is important.
  2. If a reply is needed, we ask the AI Email Writer to draft a response. Even if it is missing context it can help us draft an outline for the response.
  3. The email draft is sent to gotoHuman where the reviewer can manually edit it or ask to regenerate it with the option to even edit the prompt (Retries loop back to the AI Email Writer node)
  4. Approved email replies are automatically sent from the workflow
How to set up
  1. Most importantly, install the gotoHuman node before importing this template!
    (Just add the node to a blank canvas before importing)
  2. Set up your credentials for gotoHuman, OpenAI, and Gmail
  3. In gotoHuman, select and create the pre-built review template "Email agent" or import the ID: v81wzxwYoFYvWpmuIBgX
  4. Select this template in the gotoHuman node
Requirements
You need accounts for
  • gotoHuman (human supervision)
  • OpenAI (classification, drafting)
  • Gmail
How to customize
  • Change the predefined categories in the prompt of the AI classification agent
  • Provide the AI Email Writer with more context to create replies. Consider adding tools that allow the agent to fetch more infos about clients, your calendar, FAQs for your product,...
