Generate authentic product reviews with OpenAI for WooCommerce
Created by: Ali Khosravani || alikhosro
Ali Khosravani
Last update 23 days ago
This workflow automatically generates natural product comments using AI and posts them to your WooCommerce store. It helps boost engagement and makes product pages look more active and authentic.
How It Works
Fetches all products from your WooCommerce store.
Builds an AI prompt based on each product’s name and description.
Uses OpenAI to generate a short, human-like comment (neutral, positive, negative, or questioning).
Assigns a random reviewer name and email.
Posts the comment back to WooCommerce as a product review.
Requirements
  1. n8n version: 1.49.0 or later (recommended).
  2. Active OpenAI API key.
  3. WooCommerce installed and REST API enabled.
  4. WordPress API credentials (Consumer Key & Consumer Secret).
Setup Instructions
Import this workflow into n8n.
Add your credentials in n8n > Credentials:
OpenAI API (API key).
WooCommerce API (consumer key & secret).
Replace the sample URL https://example.com with your own WordPress/WooCommerce site URL.
Execute manually or schedule it to run periodically.
Categories
AI & Machine Learning
WooCommerce
WordPress
Marketing
Engagement
Tags
ai, openai, woocommerce, comments, automation, reviews, n8n
Note: AI-generated comments should be reviewed periodically to ensure they align with your store’s policies and brand voice.
