AI system prompt generator & optimizer (n8n + OpenAI)
Created by: Robert Breen || rbreen
Robert Breen
Last update a month ago
This workflow acts as a System Prompt Optimizer Agent.
You send it a draft prompt or goal, and it returns:
  1. A rewritten optimized system prompt that is clear, specific, and actionable.
  2. A recommendation for the best OpenAI model to use based on reasoning needs, complexity, and latency/cost tradeoffs.
The workflow uses memory for context, so you can iteratively refine prompts.
⚙️ Setup Instructions
1️⃣ Set Up OpenAI Connection
  1. Go to OpenAI Platform
  2. Navigate to OpenAI Billing
  3. Add funds to your billing account
  4. Copy your API key into the OpenAI credentials in n8n
📝 Example Question
