Extract transactions from images using unli.dev Vision API & Telegram
Last update a month ago
unli.dev + n8n + Telegram
Image Analyzer turns images sent to your Telegram bot into clean, Markdown-formatted transaction text using unli.dev Vision API. Instead of typing numbers and dates manually, the workflow downloads the photo, converts it to base64, analyzes it via API, and replies in-chat with extracted details, saving time and reducing errors.
💡 Why Use Image Analyzer?
  • Save time: Process images in seconds, cutting manual entry by up to 90%.
  • Solve pain points: No more blurry screenshot frustration; get clean Markdown transactions.
  • Faster outcomes: Per-image turnaround under 15s.
  • Competitive edge: Give staff/customers structured feedback instantly
⚡ Perfect For
  • Small business owners: Capture receipts/payments quickly.
  • Accountants/bookkeepers: Intake client receipts with fewer typos.
  • Ops/support teams: Turn messy screenshots into actionable records.
🔧 How It Works
  1. Trigger: Telegram bot receives photo.
  2. Process: Convert to base64 & prepare request.
  3. Smart Logic: Call unli.dev Vision API for text extraction.
  4. Output: Send Markdown result back to Telegram.
  5. Optional: Save structured data to Google Sheets, Airtable, or DB.
🛠 Quick Setup
  1. Import workflow JSON to your n8n instance.
  2. Add credentials: Telegram bot + unli.dev API key.
  3. Customize the system prompt (default: extract the transaction in Markdown).
  4. Test by sending a real photo to your bot.
🧩 You’ll Need
Made by: Khaisa Studio
Category: Image Analysis
Contact: Get in touch
