AI-powered credit card recommendation system with OpenAI GPT, Telegram & Google Sheets
Created by: Nishant || pandita
Nishant
Last update a month ago
Overview
Confused which credit card to actually get or swipe? With 100+ cards in the market, hidden caps, and milestone rules, most people end up leaving rewards, perks, and cashback on the table.
This workflow uses n8n + GPT + Google Sheets + Telegram to recommend the best credit card for each user’s lifestyle in under 3 seconds, while keeping the logic transparent with a ₹-value breakdown.
What does this workflow do?
This workflow:
Captures User Inputs – Users answer a 7-question lifestyle quiz via Telegram.
Stores Responses – Google Sheets logs all answers for resumption & deduplication.
Scores Answers – n8n Function nodes map single & multi-select inputs into scores.
Generates Recommendations – GPT analyses profile vs. 30+ card dataset.
Breaks Down Value – Outputs a transparent table of rewards, milestones, lounge value.
Delivers Results – Top 3 card picks returned instantly on Telegram.
Why is this useful?
Most card comparison tools only list features — they don’t personalise or calculate actual value. This workflow builds a decision engine:
🔍 Personalised → matches lifestyle to best-fit cards
💸 Transparent → shows value in real currency (rewards, milestones, lounges)
⏱ Fast → answers in under 3 seconds
🗂 Organised → Google Sheets keeps audit trail of every user + dedupe
Tools used
n8n (Orchestrator): Orchestration + logic branching
Telegram: User-facing quiz bot
Google Sheets: Database of credit cards + logs of user answers
OpenAI (GPT): Analyses user profile & generates recommendations
Who is this for?
🧑‍💻 Fintech product builders → see how AI can power recommendation engines
💳 Cardholders → understand which card fits their lifestyle best
⚙️ n8n makers → learn how to combine Sheets + GPT + chat interface into one workflow
🌍 How to adapt it for your country/location
This workflow uses a credit card dataset stored in Google Sheets. To make it work for your country:
Build your dataset → scrape or collect card details from banks, comparison sites, or official portals
Fields to include: Fees, Reward rate, Lounge access, Forex markup, Reward caps, Milestones, Eligibility.
You can use web crawlers (e.g., Apify, PhantomBuster) to automate data collection.
Update the Google Sheet → replace the India dataset with your country’s cards.
Adjust scoring logic → modify Function nodes if your cards use different reward structures (e.g., cashback %, miles, points value).
Run the workflow → GPT will analyse against the new dataset and generate recommendations specific to your country.
This makes the workflow flexible for any geography.
Workflow Highlights
✅ End-to-end credit card recommendation pipeline (quiz → scoring → GPT → result)
✅ Handles single + multi-select inputs fairly with % match scoring
✅ Transparent value breakdown in local currency (rewards, milestones, lounge access)
✅ Google Sheets for persistence, dedupe & audit trail
✅ Delivers top 3 cards in <3 seconds on Telegram
✅ Fully customisable for any country by swapping the dataset
