Answer code of conduct questions in Slack with GPT-4 & RAG technology
Created by: Trung Tran || trungtran
Trung Tran
Last update 21 days ago
📘 Code of Conduct Q&A Slack Chatbot with RAG Powered
Watch the video
Empower employees to instantly access and understand the company’s Code of Conduct via a Slack chatbot, powered by Retrieval-Augmented Generation (RAG) and LLMs.
🧑‍💼 Who’s it for
This workflow is designed for:
  • HR and compliance teams to automate policy-related inquiries
  • Employees who want quick answers to Code of Conduct questions directly inside Slack
  • Startups or enterprises that need internal compliance self-service tools powered by AI
⚙️ How it works / What it does
This RAG-powered Slack chatbot answers user questions based on your uploaded Code of Conduct PDF using GPT-4 and embedded document chunks. Here's the flow:
  1. Receive Message from Slack: A webhook triggers when a message is posted in Slack.
  2. Check if it’s a valid query: Filters out non-user messages (e.g., bot mentions).
  3. Run Agent with RAG:
    • Uses GPT-4 with Query Data Tool to retrieve relevant document chunks.
    • Returns a well-formatted, context-aware answer.
  4. Send Response to Slack: Fetches user info and posts the answer back in the same channel.
  5. Document Upload Flow:
    • HR can upload the PDF Code of Conduct file.
    • It’s parsed, chunked, embedded using OpenAI, and stored for future query retrieval.
    • A backup copy is saved to Google Drive.
🛠️ How to set up
  1. Prepare your environment:
  2. Upload the Code of Conduct PDF:
  3. Deploy the chatbot:
    • Host the webhook and connect it to your Slack app.
    • Share the command format with employees (e.g., @CodeBot Can I accept gifts from partners?)
  4. Monitor and iterate:
    • Improve chunk size or embed model if queries aren’t accurate.
    • Review unanswered queries to enhance coverage.
📋 Requirements
  • n8n (Self-hosted or Cloud)
  • Slack App (with chat:write, users:read, commands)
  • OpenAI account (embedding + GPT-4 access)
  • Google Drive integration (for backups)
  • Uploaded Code of Conduct in PDF format
🧩 How to customize the workflow
What to Customize How to Do It
🔤 Prompt style Edit the System & User prompts inside the Code Of Conduct Agent node
📄 Document types Upload additional policy PDFs and tag them differently in metadata
🤖 Agent behavior Tune GPT temperature or replace with different LLM
💬 Slack interaction Customize message formats or trigger phrases
📁 Data Store engine Swap to Pinecone, Weaviate, Supabase, etc. depending on use case
🌐 Multilingual support Preprocess text and support locale detection via Slack metadata
