Multi-timeframe trading analysis for WEEX spot market with GPT-4o & Telegram
Created by: Don Jayamaha Jr || don-the-gem-dealer
Don Jayamaha Jr
Last update a month ago
📊 WEEX Spot Market Quant AI Agent (All-in-One Multi-Agent Trading System)
⚡ Overview
This multi-agent n8n workflow delivers an automated, intelligent trading analysis system for the WEEX Spot Market. It uses GPT-4o to interpret user prompts, route them to the correct sub-agent tools, analyze technical indicators, price data, sentiment insights, and return concise trading signals via Telegram or downstream automations.
No need to download additional workflows—everything is embedded in this single orchestrated agent.
🧠 Core Features
🔹 Single-entry architecture → Built-in orchestration logic with no external subworkflow dependencies
🔹 Multi-timeframe indicator analysis → 15m, 1h, 4h, and 1d
🔹 Sentiment + news insights from crypto sources
🔹 Live price, volume, kline, and order book analysis
🔹 LLM-powered signal evaluation using GPT-4o
🔹 Telegram integration for fast human queries or autonomous alerts
🤖 Built-In Agent Modules
Module Description
Financial Analyst Tool Routes prompts, interprets tokens, and triggers sub-agents
News & Sentiment Analyst Tool Gathers real-time sentiment from crypto news sources
Technical Indicator Tools 15m, 1h, 4h, 1d indicators using WEEX spot market data
Price & Order Book Agent Fetches real-time stats, price, and structure
Trading Signal Evaluator GPT-4o merges all data and generates trading decision
🖥️ Prompt Flow Example
User Input: “Should I long or short ETH on WEEX today?”
→ Financial Analyst Agent interprets the query
→ Fetches multi-timeframe indicators, live price, sentiment
→ GPT-4o evaluates conditions and creates recommendation
→ Output delivered via Telegram:
📈 ETH/USDT Overview
• Price: $3,710
• 4h RSI: 64.5 – Slightly Overbought
• MACD: Bullish Crossover
• Market Sentiment: 🔼 Positive
Recommendation: Consider long entry with stop at $3,640.
🔧 Setup Instructions
Follow these steps to fully deploy and operate the WEEX Quant AI Agent in your n8n environment:
  1. 🟢 Get Telegram Bot API Key
    • Create your bot via @BotFather on Telegram
    • Save the token it gives you (format: 123456789:ABCdefGHIjkLMNopQRStuvWXyz)
  2. 🔑 Add OpenAI / DeepSeek Chat API Key
    • Compatible with GPT-4o (OpenAI) or DeepSeek Chat
  3. 📈 (Optional) WEEX API Keys
    • If expanding to live trading or authenticated data, get a WEEX Spot API key from your account dashboard
    • Not required for the analysis agent to function
  4. 🔗 Connect Telegram to n8n
    • Use Telegram Trigger and Telegram node with your API key
    • Ensure webhook is set correctly (or use polling mode)
✅ Example Use Cases
Scenario Outcome
“Is BTC bullish or bearish?” Merged indicator + sentiment + price analysis summary
“Get 15m and 4h trends for SOL” Multi-timeframe volatility vs macro trend report
“Latest crypto news on XRP” Real-time filtered news + DeepSeek sentiment summary
“What’s the order book structure?” Level-by-level spread analysis with buy/sell volumes
🎥 Watch the Live Demo
Watch the Live Demo
👨‍💼 Licensing & Support
🧾 © 2025 Treasurium Capital Limited Company
Architecture, prompts, and trade signal framework are IP-protected. No unauthorized rebranding or replication permitted.
📩 Connect with the Creator
Don JayamahaLinkedIn Profile
