Create data-driven SEO content briefs with AI analysis of SERP data using Bright Data
Created by: phil || phil
phil
Last update a month ago
This workflow is your all-in-one AI Content Strategist, designed to generate comprehensive, data-driven content briefs by analyzing top-ranking competitors.
It operates through a simple chat interface.
You provide a target keyword, and the workflow automates the entire research process. First, it scrapes the top 10 Google search results using the powerful Bright Data SERP API.
Then, for each of those results, it performs a deep dive, using the Bright Data Web Unblocker to reliably extract the full content from each page, bypassing any anti-bot measures.
Finally, all the gathered data—titles, headings, word counts, and page summaries—is synthesized by a Large Language Model (LLM) to produce a strategic content plan.
This plan identifies search intent, core topics, and crucial content gaps, giving you a clear roadmap to outrank the competition. This template is indispensable for SEO specialists, content marketers, and digital agencies looking to scale their content production with strategies that are proven to work.
Why Use This AI Content Strategist Workflow ?
  • Data-Driven Insights: Base your content strategy on what is actually ranking on Google, not guesswork.
  • Automated Competitive Analysis: Instantly understand the structure, length, and key themes of the top-performing articles for any keyword.
  • Strategic Gap Detection: The AI analysis highlights poorly covered topics and missed opportunities, allowing you to create content that provides unique value.
  • Massive Time Savings: Condenses hours of manual research into a fully automated process that runs in minutes.
How It Works
  1. Chat Interaction Begins: The workflow is initiated via a chat UI. The user enters a target keyword to start the analysis.
  2. Google SERP Scraping (Bright Data): The "Google SERP" node uses Bright Data's SERP API to fetch the top 10 organic results, providing the URLs for the next stage.
  3. Individual Page Scraping (Bright Data): The workflow loops through each URL. The "Access and extract data" node uses the Bright Data Web Unblocker to ensure successful and complete HTML scraping of every competitor's page.
  4. Content Extraction & Aggregation: A series of Code nodes clean the raw HTML and extract structured data (title, meta description, headings, word count). The Aggregate node then compiles the data from all 10 pages into a single dataset.
  5. AI Synthesis (OpenRouter): The "Analysis" node sends the entire compiled dataset to an LLM via OpenRouter. The AI performs a holistic analysis to identify search intent, must-cover topics, and differentiation opportunities.
  6. Strategic Brief Generation: The "Format Output" node takes the AI's structured JSON analysis and transforms it into a clean, human-readable Markdown report, which is then delivered back to the user in the chat interface.
🔑 Prerequisites
To use this workflow, you will need active accounts with both Bright Data (for web scraping) and OpenRouter (for AI model access).
Setting Up Your Credentials:
  1. Bright Data Account:
    • Sign up for a free trial account on their website.
    • Inside your Bright Data dashboard, you will need to activate both the SERP API and the Web Unblocker products to create the necessary Zones.
    • In n8n, navigate to the Credentials section, add a new "Brightdata API" credential, and enter your API key.
    • In the workflow, select your newly created credential in both the "Google SERP" node and the "Access and extract data from a specific URL" node.
  2. OpenRouter Account:
    • Sign up for an account at OpenRouter.ai.
    • Navigate to your account settings to find your API Key.
    • In n8n, go to Credentials, add a new "OpenRouter API" credential, and paste your key.
    • In the workflow, select this credential in all three "OpenRouter Chat Model" nodes.
Phil | Inforeole
🇫🇷 Contactez nous pour automatiser vos processus
