Automate document approvals with multi-level workflows using Supabase & Gmail
Created by: Alok Kumar || alokkumar
Alok Kumar
Last update a month ago
Multi-Level Document Approval & Audit Workflow
This workflow automates a document approval process using Supabase and Gmail.
Who it’s for
  • Teams that need structured multi-level document approvals.
  • Companies managing policies, contracts, or proposals.
  • Medical document need multiple lavel of review and approval.
  1. Form Trigger – A user submits a document via the form.
  2. Supabase Integration – The document is saved in the documents table.
  3. Supabase Storage – The document is saved in the bucket.
  4. Workflow Levels – Fetches the correct approval level from workflow_levels.
  5. Assign Approvers – Matches approvers by role from the users table.
  6. Approval Record – Creates an approvals record with a unique token and expiry.
  7. Email Notification – Sends an email with Approve / Reject links.
  8. Audit Logs – Records every approval request in audit_logs.
  9. Repeat - repeat the flow till all the aproval level is comepted
How to set up
  • Configure your Supabase credentials.
  • Create tables as per data model given.
  • Create a storage bucket in Supabase Storage.
  • Connect your Gmail account.
  • Adjust approval expiry time (48h default).
  • Deploy and test via the Form Trigger.
Customization
  • Add multiple approval levels by chaining workflow_levels.
  • Replace Gmail with Slack, Teams, or another notification channel.
  • Adjust audit logging for compliance needs.
  • Update the endpoint http://localhost:5678/webhook-test/ based on instance and env (remove test if you run in prod)
  • Update the bucket name.
Important steps
1. Form Submit
  • Triggered when by submiting form
  • Captures form parameters:
    • Title (Document Title)
    • Description (Document Description)
    • file (Document need for approval)
2. Webhook Entry Point
  • Triggered when an approver clicks the Approve or Reject link in email.
  • Captures query parameters:
    • token (approval token)
    • decision (approved/rejected)
3. Approval Data Retrieval & Update
  • Fetch approval record from Supabase (approvals) using token.
  • Update approval status:
    • Approved → moves to next workflow level or final approval.
    • Rejected → document marked as rejected immediately.
  • Records acted_at timestamp.
4. Decision Check
  • IF Node checks whether the decision is approved or rejected.
  • Reject Path → Update document status to Rejected in documents.
  • Approve Path → Continue workflow level progression.
5. Workflow Level Progression
  • Fetch details of the current workflow level.
  • Identify the next level (workflow_levels) based on level_number.
✅ If Next Level Exists:
  • Retrieve approvers by role_id.
  • Generate unique approval tokens.
  • Create new approval records in approvals.
  • Send email notifications with approval/reject links.
❌ If No Next Level (Last Level):
  • Update document status to Approved in documents.
6. Audit Logging
  • Every approval action is logged into audit_logs table:
    • document_id
    • action (e.g., approval_sent, approved, rejected)
    • actor_email (system/approver)
    • details (workflow level, role info, etc.)
📨 Email Template
Approval request email includes decision links:
<p>Please review the document:</p>
<p>
  <a href="http://localhost:5678/webhook-test/doc-approval?token={{$json.token}}&decision=approved">✅ Approve</a> |
  <a href="http://localhost:5678/webhook-test/doc-approval?token={{$json.token}}&decision=rejected">❌ Reject</a>
</p>
Happy Automating! 🚀
