AI video automation engine - generate & publish YT shorts with Veo-3 or Sora 2
Created by: SuS || sulieman-said
SuS
Last update a month ago
Product Overview
Scale short-form content without scaling your team. This template turns idea discovery → prompt & text generation → Veo-3 video rendering → vertical formatting → multi-channel publishing into one cohesive pipeline. It’s built natively on n8n, so you keep full control, self-host if you want, and extend every step with your own logic.
What’s Inside (Modular Building Blocks)
  • Idea Engine – AI generates concise, surprising facts and a visual metaphor per topic (swappable LLM/provider).
  • Prompt & Text Composer – Crafts an 8-second, cinematic Veo-3 prompt + title, caption, description, hashtags, tags in a consistent brand voice.
  • Renderer IntegrationKie.ai → Veo-3 (16:9, 1080p) for fast, cinematic clips.
  • Vertical Formatter – FFmpeg pipeline converts to 1080×1920, adds top/bottom text bands (15–20 words), and preserves loop smoothness.
  • Multi-Channel Distribution – Uploads to YouTube Shorts and Telegram for internal review/approvals.
  • Scheduler & Orchestration – CRON triggers, retries, and lightweight polling make the system dependable for daily publishing.
Why These Components (and why they work together)
  • Veo-3 via Kie.ai provides a sweet spot of quality + speed, ideal for short loops where style coherence matters.
  • n8n brings vendor-neutral orchestration: swap LLMs, add rate limits, branch flows, or trigger on events—without rewriting your stack.
  • FFmpeg ensures a platform-native look (9:16, crisp text bands, no blurry hacks).
  • Separation of concerns (idea → text → render → edit → publish) makes it easy to A/B test any stage independently.
Key Benefits
  • Hands-Free Consistency – Daily output with a repeatable creative pattern that audiences recognize.
  • Brand-Safe Copy – Titles, descriptions, and hashtags follow a controlled structure—polished by design.
  • Time Savings – Replace fragmented tooling with one pipeline; no manual re-formatting, captioning, or re-uploads.
  • Creator-Grade Quality – Cinematic loops optimized for watch time and retention on Shorts/Reels.
  • Own Your Stack – Self-hosted orchestration and storage; no lock-in.
Reuse & Extension Ideas
  • Topic CMS – Feed topics from Google Sheets / Notion and mark each as “published”—perfect for content calendars.
  • Multi-Language – Duplicate the text composer for EN/DE outputs; upload the same clip with localized metadata.
  • Thumbnail/Preview Track – Add an image generator step for platform cards or YouTube custom thumbnails.
  • Analytics Feedback Loop – Fetch video performance, score ideas, and prioritize winning angles automatically.
  • Compliance & Fact Trails – Store sources next to each post for quick audits and edits.
  • Storage & Delivery – Push masters to S3/Backblaze, serve via CDN for faster IG ingestion.
  • More Channels – Add TikTok, X, LinkedIn publishers or a newsletter export.
  • A/B Creative – Render multiple Veo-3 seeds, rotate captions/CTAs, and compare retention.
Who It’s For
  • Agencies wanting repeatable, branded Shorts at scale.
  • Creators & Media Teams who need daily output with minimal overhead.
  • Product Marketing looking to convert docs/reports into snackable, evergreen video facts.
  • Startups building audience fast without adding headcount.
Technical Notes (at a glance)
  • Orchestration: n8n (self-hosted or cloud)
  • Video: Veo-3 via Kie.ai (16:9 render → FFmpeg vertical remaster 1080×1920)
  • Text Stack: Any LLM provider (swappable); outputs normalized for each platform
  • Distribution: YouTube Data API v3, Telegram Bot API
  • Security: API keys via n8n credentials/ENV; public URL endpoint only serves whitelisted .mp4 filenames with proper headers
  • Reliability: CRON triggers, bounded retries/polling, and safe fallbacks to avoid stuck runs
Who to use it
To enhance the completeness, add specific step-by-step setup instructions for users to implement the workflow easily:
  1. Install Prerequisites
    • Set up n8n on your server or local machine (production mode with reverse proxy).
    • Install FFmpeg and ensure fonts (e.g., DejaVu Sans) are available.
  2. Configure API Credentials
    • Get a Perplexity API key for idea generation.
    • Request a Kie.ai API key for Veo-3 video rendering.
    • Set up YouTube OAuth2 (enable YouTube Data API v3 in Google Cloud Console).
    • Create a Telegram bot token via BotFather.
    • Store all keys as environment variables in n8n (avoid hardcoding).
  3. Prepare Storage
    • Create a working directory accessible by n8n with read/write rights.
    • Ensure enough disk space for video caching (approx. 50–200 MB per run).
  4. Set Scheduling
    • Add CRON triggers for automatic execution (e.g., twice daily).
    • Example:
      0 12 04 * * * → 04:12 AM daily
      0 12 16 * * * → 04:12 PM daily
  5. Define Variables
    • File naming conventions:
      • name_vorher = raw 16:9 video
      • name_nachher = final 9:16 video
    • Set topic = content niche (e.g., history, ocean, futurism).
  6. Build Workflow Steps in n8n
    • Idea Generation: Perplexity node for viral fact.
    • Prompt Agent: Expand into full package (prompt, caption, hashtags).
    • Video Generation: Kie.ai Veo-3 API request (poll until success).
    • Download & Edit: Save raw file, convert to 9:16 with FFmpeg overlays.
    • Notifications & Uploads:
      • Telegram node → send video.
      • YouTube node → upload with title, description, tags.
  7. Test End-to-End
    • Run the workflow manually once.
    • Verify video rendering, FFmpeg subtitles, Telegram message, YouTube & IG uploads.
  8. Go Live
    • Enable CRON triggers.
    • Monitor first runs for errors (API limits, FFmpeg paths, token expiry).
Why Buy This Template
You’re not buying a script—you’re buying a production-ready system with a deliberate creative pattern, best-practice formatting, and shipping-grade integrations. It reduces ramp-up from weeks to hours and gives you a flexible base you can keep evolving.
