Migrate Pinecone index to Weaviate class with Airtable pagination
Created by: Br1 || bruno-menegolli
Br1
Last update a month ago
Who’s it for
This workflow is designed for developers, data engineers, and AI teams who need to migrate a Pinecone Cloud index into a Weaviate Cloud class index without recalculating the vectors (embeddings).
It’s especially useful if you are consolidating vector databases, moving from Pinecone to Weaviate for hybrid search, or preparing to deprecate Pinecone.
⚠️ Note: The dimensions of the two indexes must match.
The workflow automates migration by batching, formatting, and transferring vectors along with their metadata:
  1. Initialization – Uses Airtable to store the pagination token. The token starts with a record initialized as INIT (Name=INIT, Number=0).
  2. Pagination handling – Reads batches of vector IDs from the Pinecone index using /vectors/list, resuming from the last stored token.
  3. Vector fetching – For each batch, retrieves embeddings and metadata fields from Pinecone via /vectors/fetch.
  4. Data transformation – Two Code nodes (Prepare Fetch Body and Format2Weaviate) are included to correctly structure the body of each HTTP request and map metadata into Weaviate-compatible objects.
  5. Data loading – Inserts embeddings and metadata into the target Weaviate class through its REST API.
  6. State persistence – Updates the pagination token in Airtable, ensuring the next run resumes from the correct point.
  7. Scheduling – The workflow runs on a defined schedule (e.g., every 15 seconds) until all data has been migrated.
How to set up
  1. Airtable setup
    • Create a Base (e.g., Cycle) and a Table (e.g., NextPage).
    • The table should have two columns:
      • Name (text) → stores the pagination token.
      • Number (number) → stores the row ID to update.
    • Initialize the first and only row with (INIT, 0).
  2. Source and target configuration
    • Make sure you have a Pinecone index and namespace with embeddings.
    • Manually create a target Weaviate Cluster and a target Weaviate Class with the same vector dimensions.
    • In the Parameters node of the workflow, configure the following values:
    Parameter Description Example Value
    pineconeIndex The name of your Pinecone index to read vectors from. my-index
    pineconeNamespace The namespace inside the Pinecone index (leave empty if unused). default
    batchlimit Number of records fetched per iteration. Higher = faster migration but heavier API calls. 100
    weaviateCluster REST endpoint of your Weaviate Cloud instance. https://dbbqrc9itXXXXXXXXX.c0.europe-west3.gcp.weaviate.cloud
    weaviateClass Target class name in Weaviate where objects will be inserted. MyClass
  3. Credentials
    • Configure Pinecone API credentials.
    • Configure Weaviate Bearer token.
    • Configure Airtable API key.
  4. Activate
    • Import the workflow into n8n, update the parameters, and start the schedule trigger.
Requirements
  • Pinecone Cloud account with a configured index and namespace.
  • Weaviate Cloud cluster with a class defined and matching vector dimensions.
  • Airtable account and base to store pagination state.
  • n8n instance with credentials for Pinecone, Weaviate, and Airtable.
How to customize the workflow
  • Adjust the batchlimit parameter to control performance (higher values = fewer API calls, but heavier requests).
  • Adapt the Format2Weaviate Code node if you want to change or expand the metadata stored.
  • Replace Airtable with another persistence store (e.g., Google Sheets, PostgreSQL) if preferred.
  • Extend the workflow to send migration progress updates via Slack, email, or another channel.
