Create structured logging system with Supabase and Log4j2-style levels
Created by: Elodie Tasia || ladypixl
Elodie Tasia
Last update a month ago
Categories
Create centralized, structured logs directly from your n8n workflows, using Supabase as your scalable log database.
Whether you're debugging a workflow, monitoring execution status, or tracking error events, this template makes it easy to log messages in a consistent, structured format inspired by Log4j2 levels (DEBUG, INFO, WARN, ERROR, FATAL).
You’ll get a reusable sub-workflow that lets you log any message with optional metadata, tied to a workflow execution and a specific node.
What this template does
  • Provides a sub-workflow that inserts log entries into Supabase.
  • Each log entry supports the following fields:
    • workflow_name: Your n8n workflow identifier
    • node_name: last executed node
    • execution_id: n8n execution ID for correlation
    • log_level: One of DEBUG, INFO, WARN, ERROR, FATAL
    • message: Textual message for the log
    • metadata: Optional JSON metadata (flexible format)
  • Comes with examples for diffrerent log levels:
    Easily call the sub-workflow from any step with a Execute Workflow node and pass dynamic parameters.
Use Cases
  • Debug complex workflows without relying on internal n8n logs.
  • Catch and trace errors with contextual metadata.
  • Integrate logs into external dashboards or monitoring tools via Supabase SQL or APIs.
  • Analyze logs by level, time, or workflow.
Requirements
To use this template, you'll need:
  • A Supabase project with:
    • A log_level_type enum
    • A logs table matching the expected structure
  • A service role key or supabase credentials available in n8n.
The table shema and SQL scripts are given in the template file.
How to Use This Template
  • Clone the sub-workflow into your n8n instance.
  • Set up Supabase credentials (in the Supabase node).
  • Call the sub-workflow using the Execute Workflow node.
  • Provide input values like:
  "workflow_name": "sync_crm_to_airtable",
  "execution_id": {{$execution.id}},
  "node_name": "Airtable Insert",
  "log_level": "INFO",
  "message": "New contact pushed to Airtable successfully",
  "metadata": {
    "recordId": "rec123",
    "fields": ["email", "firstName"]
  • Repeat anywhere you need to log custom events.
