Transfer workflows with credentials & sub-workflow management between n8n instances
Last update a month ago
Categories
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
Export Workflows Between n8n Instances
Copy workflows between n8n instances — with optional credential export and automatic sub-workflow adjustments.
🧠 How it Works
This workflow copies a selected workflow from a SOURCE n8n server to a TARGET server and guides you through safe checks:
  • Name conflict check: If a workflow with the same name exists on the target the export is stopped.
  • Sub-workflows: Detects calls to sub-workflows.
    • If all sub-workflows exist on the target (same names), references are auto-updated and the export continues.
    • If any are missing, the form shows what’s missing and lets you cancel or proceed anyway.
  • Credentials: Detects nodes using credentials and lets you export those credentials along with the workflow.
    • The workflow can only apply credential corrections for the credentials that you choose to export with it.
    • At the end, the form lists which credentials were successfully exported.
💡 For in-depth behavior and edge cases, see the Notes inside the workflow (Setup, How It Works, and Credential Issues).
🚀 How to Use
  1. Run this workflow on your SOURCE server.
  2. Follow the step-by-step form: pick the workflow to export, choose whether to include credentials, and review sub-workflow checks. Done.
⚙️ Setup
  • Create an n8n API key on both servers (SOURCE and TARGET).
  • On the SOURCE server, create two n8n API credentials in n8n: one for SOURCE and one for TARGET (using the respective base URL and key).
  • Configure the nodes in this workflow with these two credentials.
  • Detailed step-by-step instructions are available in the workflow notes.
✅ Once configured, you’ll be ready to migrate workflows between servers in just a few clicks.
