Generate & post animated anime wallpapers to TikTok with Flux AI and Fal AI
Created by: Fariez || kelaswfa
Fariez
Last update 25 days ago
Automatically create AI-generated anime wallpapers, transform them into animated videos, and post them to TikTok — all with one n8n workflow.
What Problem Is This Workflow Solving? / Use Case
Creating and publishing engaging anime content for TikTok is often time-consuming. From generating ideas, creating visuals, animating them, and finally uploading to TikTok, the process usually requires multiple tools and manual effort.
This workflow solves that by automating the entire pipeline — from anime wallpaper generation to video animation and auto-posting on TikTok — all in one place. Perfect for content creators, anime enthusiasts, and marketers who want to consistently deliver fresh, unique TikTok content without the hassle.
Who Is This For
  • Anime Creators & Fans: Share unique AI-generated anime content with your TikTok audience.
  • Content Creators & Influencers: Keep your TikTok feed active without spending hours designing and editing.
  • Marketers & Social Media Managers: Automate anime-themed campaigns to attract new audiences.
  • Automation Enthusiasts: Explore creative ways to connect AI models and publishing platforms using n8n.
What This Workflow Does
  • Collects anime topic & style via an n8n Form (or scheduled trigger).
  • Uses Groq + GPT-OSS to generate a text-to-image prompt.
  • Creates an anime wallpaper using the Flux AI model (Pollination AI).
  • Transforms the wallpaper into an animated video with Fal AI (Minimax Hailuo 02 Fast).
  • Automatically posts the final video to TikTok via the GetLate API.
How to Use
  1. Set up Groq
    • Add your Groq API Key to the Groq Chat Model node.
    • Select an LLM model (default: OpenAI GPT-OSS 120B).
  2. Set up TikTok posting
    • Get your API key from getlate.dev.
    • Add the credentials to the Upload IMG and TikTok Post nodes.
  3. Set up Fal AI for video generation
    • Get your API key from Fal.ai and top up credits.
    • Add your Fal AI credentials to the Create Video, Get Status, and Get Video nodes.
  4. Run the workflow
    • Open the n8n Form URL (Test or Production).
    • Enter your anime topic and style.
    • The workflow will generate the image, animate it, and post directly to TikTok.
Possible Customizations:
  • Replace the default Form Trigger with a Scheduled Trigger.
  • Connect a topics database (e.g., Google Sheets or Airtable) to automatically generate and post animated anime wallpapers on TikTok at regular intervals.
