Answer questions with factual web search using Telegram, Tavily and GPT-5
Last update a month ago
🧠 Telegram Search Assistant — Tavily + AI/ML API
This n8n workflow lets users ask questions in Telegram and receive concise, fact-based answers.
It performs a web search with Tavily, then uses AIMLAPI (GPT-5) to summarize results into a clear 3–4 sentence reply.
The flow ensures grounded, non-hallucinated answers.
🚀 Features
  • 📩 Telegram-based input
  • ⌨️ Typing indicator for better UX
  • 🔎 Web search with Tavily (JSON results)
  • 🧠 Summarization with AIMLAPI (openai/gpt-5-chat-latest)
  • 📤 Replies in the same chat/thread
  • Guardrails against hallucinations
🛠 Setup Guide
1. 📲 Create Telegram Bot
  • Talk to @BotFather
  • Use /newbot → choose a name and username
  • Save the bot token
2. 🔐 Set Up Credentials in n8n
  • Telegram API: use your bot token
  • Tavily: add your Tavily API key
  • AI/ML API: add your API key
    • Base URL: https://api.aimlapi.com/v1
3. 🔧 Configure the Workflow
  • Open the n8n editor and import the JSON
  • Update credentials for Telegram, Tavily, and AIMLAPI
⚙️ Flow Summary
Node Function
📩 Receive Telegram Msg Triggered when user sends text
⌨️ Typing Indicator Shows “typing…” to user
🔎 Web Search Queries Tavily with user’s message
🧠 LLM Summarize Summarizes search JSON into a factual answer
📤 Reply to Telegram Sends concise answer back to same thread
📁 Data Handling
  • By default: no data stored
  • Optional: log queries & answers to Google Sheets or a database
💡 Example Prompt Flow
User sends:
When is the next solar eclipse in Europe?
Bot replies:
The next solar eclipse in Europe will occur on August 12, 2026.
It will be visible as a total eclipse across Spain, with partial views in much of Europe.
The maximum eclipse will occur around 17:46 UTC.
🔄 Customization
  • Add commands: /help, /sources, /news
  • Apply rate-limits per user
  • Extend logging to Google Sheets / DB
  • Add NSFW / profanity filters before search
🧪 Testing
  • Test end-to-end in Telegram (not just “Execute Node”)
  • Add a fallback reply if Tavily returns empty results
  • Use sticky notes for debugging & best practices
📎 Resources
