Create a dynamic Telegram bot menu system with multi-level navigation
Created by: Ruslan Elishev || relishev
Ruslan Elishev
Last update 4 months ago
🤖 Telegram Bot with Dynamic Multi-Level Menu System
What This Workflow Does
Ever wanted to build a Telegram bot with professional-looking menus that actually work? This n8n workflow creates an interactive bot with dynamic inline keyboards, multi-level navigation, and smart button routing - all without writing complex code from scratch.
The bot features a clean separation between your menu structure and business logic. This means you can change your menus anytime without breaking the underlying functionality. Think of it like WordPress menus but for Telegram bots - you define the navigation, and the workflow handles everything else.
Your bot will respond with personalized messages, remember user context, handle button clicks smoothly (no annoying loading spinners!), and route different actions to specialized handlers. Whether users are rating your service, checking their subscription status, or navigating through settings, everything just works.
🚀 Getting Started in 3 Minutes
Step 1: Get Your Bot Token
Head over to Telegram and chat with @BotFather. Create a new bot (or use an existing one) and grab that token. In the workflow, find the purple "Set Bot Token" node and replace [!!! YOUR_BOT_TOKEN_HERE !!!] with your actual token.
Step 2: Activate the Magic
Save the workflow, click on "Production" tab, and you'll see a webhook URL. Toggle the workflow to Active. That's it - your bot is live!
Step 3: See It In Action
Message your bot on Telegram. Type /start and watch your beautiful menu appear. Click around, explore the buttons - everything is already set up and working.
🎨 Making It Yours
Want to Add Your Own Menus?
Open the workflow and look for the sticky note titled "📖 COMPLETE GUIDE: ADDING MENUS & ACTIONS". I've written step-by-step instructions right there in the workflow. You'll find exact examples showing how to add a contact menu, subscription status checker, or whatever you need.
The beauty is in the simplicity - menus are just text and buttons. No complicated logic mixed in. Check the "📚 REAL EXAMPLES" sticky note for copy-paste templates you can modify.
Need Custom Actions?
When a button needs to actually DO something (save data, call an API, send an email), that's where handlers come in. The workflow includes 7 pre-built handlers for common tasks like ratings, language switching, and analytics. Want to add your own? The "💡 ADDING HANDLERS" sticky note walks you through it.
💡 Why This Workflow Is Different
Most Telegram bot tutorials have you mixing menu code with business logic, making changes a nightmare. This workflow separates everything cleanly. Your menus live in one place, your logic in another. It's like having a control panel for your bot.
The workflow also solves a common n8n limitation - the native Telegram node doesn't support dynamic inline keyboards. Instead of giving up, this workflow uses HTTP requests directly to the Telegram API, giving you full control over every feature.
🔧 Pro Tips from the Trenches
After building dozens of Telegram bots, here's what I've learned:
  • Always include a "Back" button - users panic without an escape route
  • Use emojis in your buttons - they make everything friendlier
  • Test each menu path after changes - one typo can break navigation
  • Keep action handlers focused - one handler, one job
Hit a snag? Check the "🐛 TROUBLESHOOTING & TIPS" sticky note in the workflow. I've documented all the common "gotchas" and their fixes.
📦 What's Included
This workflow comes with everything you need:
  • Centralized menu configuration system
  • Smart routing that automatically detects which button was pressed
  • 7 ready-to-use action handlers (modify or replace as needed)
  • Parallel processing for lightning-fast responses
  • Built-in error handling with fallback menus
  • Comprehensive documentation right in the workflow via sticky notes
🚀 Taking It Further
Once you're comfortable with the basics, this architecture scales beautifully. Connect a database to remember user preferences. Integrate with your CRM to pull customer data. Add payment processing for a shopping bot. The modular design means you can enhance one part without touching the others.
The workflow sticky notes contain advanced examples for multi-language support, user authentication, and API integrations. Everything is explained in plain English with code examples you can actually use.
🤝 One Last Thing
This workflow started as a simple dynamic menu with rating workflow and evolved into something much more powerful through community feedback. If you build something cool with it, I'd love to hear about it. And if you get stuck, remember - all the answers are in those sticky notes. I spent way too much time making them ridiculously detailed so you wouldn't have to struggle like I did.
Happy bot building! 🎯
Version: 1.0 - Centralized Menu System with Branching
Author: Ruslan Elishev
