Generate AI product ad images from Google Sheets using Fal.ai and OpenAI
Created by: Jaruphat J. || jaruphatj
Jaruphat J.
Last update a day ago
⚠️ Note: All sensitive credentials should be set via n8n Credentials or environment variables. Do not hardcode API keys in nodes.
Who’s it for
Marketers, creators, and automation builders who want to generate UGC-style ad images automatically from a Google Sheet. Ideal for e‑commerce SKUs, agencies, or teams that need many variations quickly.
What it does (Overview)
This template turns a spreadsheet row into ad images ready for campaigns.
  • Zone 1 — Create Ad Image: Reads product rows, downloads image, analyzes it, generates prompts, appends results back into Google Sheet.
  • Zone 2 — Create Image (Fal nano‑banana): Generates ad image variations, polls Fal.ai API until done, uploads to Drive, and updates sheet with output URLs.
Requirements
  • Fal.ai API key (env: FAL_KEY)
  • Google Sheets / Google Drive OAuth2 credentials
  • OpenAI (Vision/Chat) for image analysis
  • A Google Sheet with columns for product and output
  • Google Drive files set to Anyone with link → Viewer so APIs can fetch them
How to set up
  1. Credentials: Add Google Sheets + Google Drive (OAuth2), Fal.ai (Header Auth with Authorization: Key {{$env.FAL_KEY}}), and OpenAI.
  2. Google Sheet: Create sheets with the following headers.
Sheet: product
product_id | product_name | product_image_url | product_description | campaign | brand_notes | constraints | num_variations | aspect_ratio | model_target | status
Sheet: ad_image
scene_ref | product_name | prompt | status | output_url
  1. Import the workflow: Use the provided JSON. Confirm node credentials resolve.
  2. Run: Start with Zone 0 to verify prompt-only flow, then test Zone 1 for image generation.
Zone 1 — Create Ad Image (Prompt-only)
Reads product row, normalizes Drive link, analyzes image, generates structured ad prompts, appends to ad_image sheet.
Reads product row, converts Drive link, generates image(s) with Fal nano‑banana, polls until complete, uploads to Drive, updates sheet.
Node settings (high‑level)
Drive Link Parser (Set)
  const u = $json.product || '';
  const q = u.match(/[?&]id=([\-\w]{25,})/);
  const d = u.match(/\/d\/([\-\w]{25,})/);
  const any = u.match(/[\-\w]{25,}/);
  const id = q?.[1] || d?.[1] || (any ? any[0] : '');
  return id ? 'https://drive.google.com/uc?export=view&id=' + id : '';
How to customize the workflow
  • Adjust AI prompts to change ad style (luxury, cozy, techy).
  • Change aspect ratio for TikTok/IG/Shorts (9:16, 1:1, 16:9).
  • Extend Sheet schema for campaign labels, audiences, hashtags.
  • Add distribution (Slack/LINE/Telegram) after Drive upload.
Troubleshooting
  • JSON parameter needs to be valid JSON → Ensure expressions return objects, not strings.
  • 403 on images → Make Drive files public (Viewer) and convert links.
  • Job never completes → Check status_url, retry with *-fast models or off‑peak times.
Template metadata
  • Uses: Google Sheets, Google Drive, HTTP Request, Wait/If/Switch, Code, OpenAI Vision/Chat, Fal.ai models (nano‑banana)
Visuals
Workflow Diagram
Workflow Diagram
Example Product Image
Alt text
Product Image - nano Banana
Alt text Alt text Alt text Alt text
