Create & auto-post Instagram reels with AI clones: Script-to-post (Heygen + Submagic + Blotato)
Last update a month ago
AI Clone Instagram Influencer Reel Builder + Auto-Post (Heygen + Submagic + Blotato)
Description
Turn an idea into a finished Instagram Reel—end to end, on autopilot.
This template generates a compelling Reel script, sends it to Heygen to produce an AI avatar/clone video, applies dynamic on-video captions with Submagic, then uploads and auto-posts to Instagram via Blotato, complete with a tailored AI-written caption. Ideal for creators, agencies, and brands who want consistent short-form output without manual editing.
👉 Watch step-by-step automation builds on YouTube: https://youtu.be/MmZxLuAkqig?si=DRfS89yQlSlbMbfZ
What This Template Does
✍️ Generates a short-form Reel script from your topic/idea (optimized hook → body → close).
🧑‍🎤 Creates an AI avatar video using Heygen (character + voice) from that script.
🅰️ Adds stylized overlaid captions using Submagic (template selectable).
☁️ Uploads media to Blotato and auto-posts to Instagram Reels.
🧠 Writes an IG caption (with hashtags) using an AI Caption Agent tuned for engagement.
How It Works (Node Flow)
Chat Trigger – Send a topic/idea to start the run.
Instagram Script Generator (Agent) – Creates a 25–30s script (hook → insights → soft CTA).
POST to Heygen – Generates an avatar video from the script (avatar_id, voice_id, size).
Wait & Poll – Checks Heygen status until the video is ready.
POST to Submagic – Creates a project and applies your caption style (e.g., “Hormozi 2”).
Wait & Poll – Retrieves the captioned video URL when completed.
Upload media (Blotato) – Uploads the final video to your Blotato account.
Instagram Caption Agent – Produces an on-brand IG caption + hashtag block from the original script.
Create Post (Blotato) – Publishes to Instagram as a Reel with the AI caption and uploaded media.
Required Credentials
OpenAI (or compatible) – for script + caption agents.
Heygen API – HTTP Header Auth (API key).
Submagic API – HTTP Header Auth (API key).
Blotato API – Account + token.
(Optional) KodeKey/Base URL if you route OpenAI-compatible models through your gateway.
Best practice: store all secrets in n8n Credentials, not hard-coded in nodes.
Quick Start
Import the template into n8n.
Create/assign credentials for OpenAI (or compatible), Heygen, Submagic, and Blotato.
In Heygen, set your avatar_id and voice_id (or swap with your own).
In Submagic, set templateName, language, and style preferences.
In Blotato, confirm the accountId and instagramMediaType: reel.
Run the workflow from the Chat Trigger with a topic (e.g., “3 money habits for 2025”).
Confirm the Reel shows up in your connected Instagram account.
Customization Tips
Script Persona: Adjust the agent system prompt (niche, tone, audience).
Caption Style: Tweak the Caption Agent for hook length, CTAs, and hashtag strategy.
Heygen Output: Change dimension to 1080×1920 for full-HD vertical.
Submagic Template: Swap templateName to match your brand.
Posting Targets: Extend Blotato to cross-post to TikTok/YouTube Shorts.
Error Handling & Reliability
Uses Wait + status polling for both Heygen and Submagic before downstream steps.
Includes IF checks to re-poll when processing is not complete.
Recommendation: add Slack/Email alerts and Retry options for production use.
Ideal For
Solo creators and founders posting daily
Social media managers and agencies
Edu/Coach brands scaling short-form content
