Convert Reddit business pain points to LinkedIn posts with AI and Seedream
Created by: Daniel Lianes  || daniellianes
Daniel Lianes
Last update 20 days ago
Reddit Pain Point to LinkedIn Content Automation
Auto-discover real marketing problems and create viral LinkedIn content automatically
This workflow transforms scattered Reddit discussions into a systematic lead generation machine by discovering actual marketing problems businesses face and automatically converting them into authoritative LinkedIn content that attracts qualified prospects.
Overview
This workflow handles the complete pain point discovery and content creation process using advanced AI analysis and automation. It manages Reddit API authentication, multi-source community monitoring, intelligent problem identification, solution development, and LinkedIn publishing with built-in error handling and content optimization for maximum engagement.
Core Function: Real-time market intelligence that transforms Reddit conversations into high-converting LinkedIn content, positioning you as the expert who understands and solves specific business problems in your target industries.
Key Capabilities
  • Real-time pain point discovery - Monitor 10+ specialized B2B subreddits for actual marketing problems being discussed right now
  • Multi-industry intelligence - Track Dentistry, Beauty, Accounting, Real Estate, Lawyer, Ecommerce, HR, Online Education, Coaching, and Interior Design sectors simultaneously
  • AI-powered problem translation - GPT-4.1 mini converts technical Reddit complaints into clear business problems with realistic context
  • Solution architecture - Automatically proposes specific automation solutions with viability scoring and ROI estimates
  • LinkedIn content automation - Gemini 2.5 Pro creates Spanish PYME-focused posts with professional imagery via Freepik Seedream V4
  • Compound intelligence - System learns and improves, building a comprehensive database of market problems and solutions over time
  • Authority positioning - Creates content that makes prospects think "this person understands exactly what we're facing"
Tools Used
  • n8n: The automation platform orchestrating both discovery and content creation systems
  • Reddit API: Direct access to community discussions and pain point identification
  • OpenRouter: Gateway to advanced AI models (GPT-4.1 mini, Gemini 2.5 Pro)
  • GPT-4.1 mini: Lightning-fast pain point detection and solution architecture
  • Gemini 2.5 Pro: Advanced copywriting and visual prompt creation
  • SerpAPI: Real-time market research and trend integration
  • Freepik API: Ultra-realistic business imagery generation with Seedream V4
  • Google Sheets: Smart knowledge base for pain point storage and tracking
  • LinkedIn Business API: Professional content publishing and distribution
How to Install
Setup Time: 20-25 minutes for complete configuration
  1. Import the Workflow: Download the .json file and import it into your n8n instance
  2. Configure Reddit Access: Set up Reddit OAuth2 credentials for community monitoring
  3. Set Up AI Processing: Add your OpenRouter API key for GPT-4.1 mini and Gemini 2.5 Pro access
  4. Configure Market Research: Add SerpAPI credentials for real-time trend integration
  5. Set Up Image Generation: Configure Freepik API access for professional imagery
  6. Configure LinkedIn Publishing: Set up LinkedIn Business API for automated posting
  7. Create Knowledge Base: Copy the provided Google Sheets template and configure access
  8. Test Both Systems: Run research cycle and content creation independently
  9. Deploy Automation: Activate schedules (research every 10 days, content daily 9:30 AM)
Use Cases
Marketing Agencies: Discover client industry problems automatically and create content that demonstrates deep market understanding, positioning your agency as the one that "gets" specific industry challenges.
Automation Consultants: Identify businesses struggling with manual processes through their Reddit discussions, then create educational content showcasing relevant automation solutions that attract pre-qualified leads.
Business Coaches: Build authority through market insight by addressing real problems business owners are actively discussing, establishing credibility as the expert with solutions to specific industry challenges.
Freelance Specialists: Develop niche expertise by focusing content on specific industry pain points discovered through community monitoring, enabling premium positioning and higher rates.
Content Creators: Generate endless content ideas based on real market problems rather than guessing what to write about, ensuring every post addresses actual audience needs.
B2B SaaS Companies: Monitor target market discussions to identify feature gaps, positioning opportunities, and create educational content that demonstrates product-market fit.
Enterprise Sales Teams: Stay informed about prospect challenges through community intelligence, enabling more relevant outreach and positioning discussions.
Pre-configured Google Sheets Template
Knowledge Base Template
Make a copy of the template to your Google Drive and update the sheet ID in the workflow nodes for proper pain point storage and retrieval.
Connect with Me
LinkedIn: https://www.linkedin.com/in/daniel-lianes/
Discovery Call: https://cal.com/averis/asesoria
Consulting Session: https://cal.com/averis/consultoria-personalizada
Was this helpful? Let me know!
Your feedback is very valuable and helps me create better resources for the n8n community.
Want to take automation to the next level?
If you're looking to optimize your business processes or need expert help with a project, here's how I can assist you:
Advisory (Discovery Call): Do you have a process in your business that you'd like to automate but don't know where to start? In this initial call, we'll explore your needs and see if automation is the ideal solution for you.
Schedule a Discovery Call
Personalized Consulting: If you already have a specific problem, an integration challenge, or need hands-on help building a custom workflow, this session is for you. Together, we'll find a powerful solution for your case.
Book Your Consulting Session
Stay Up to Date
For more tricks, ideas, and news about automation and AI, let's connect on LinkedIn!
Follow me on LinkedIn
#n8n #automation #reddit #linkedin #ai #painpoints #seedream #contentcreation #leadgeneration #gemini #businessautomation #marketresearch #contentmarketing #socialmedia #freepik #gpt4 #productivity #entrepreneurship #pymes #averistech
