Generate MemeCoin Art with Gemini Flash & NanoBanana and Post to Twitter
Created by: Jay Emp0 || jay-emp0
Jay Emp0
Last update a month ago
🐱 MemeCoin Art Generator - using Gemini Flash NanoBanana & upload to Twitter
Watch the Youtube Tutorial video
Watch the video
Automatically generates memecoin art and posts it to Twitter (X) powered by Google Gemini, NanoBanana image generation, and n8n automation.
🧩 Overview
This workflow creates viral style memecoin images (like Popcat) and posts them directly to Twitter with a witty, Gen Z style tweet.
It combines text to image AI, scheduled triggers, and social publishing, all in one seamless flow.
Workflow flow:
  1. Define your memecoin mascot (name, description, and base image URL).
  2. Generate an AI image prompt and a meme tweet.
  3. Feed the base mascot image into Gemini Image Generation API.
  4. Render a futuristic memecoin artwork using NanoBanana.
  5. Upload the final image and tweet automatically to Twitter.
🧠 Workflow Diagram
Workflow Diagram
⚙️ Key Components
Node Function
Schedule Trigger Runs automatically at chosen intervals to start meme generation.
Define Memecoin Defines mascot name, description, and base image URL.
AI Agent Generates tweet text and creative image prompt using Google Gemini.
Google Gemini Chat Model Provides trending topic context and meme phrasing.
Get Source Image Fetches the original mascot image (e.g., Popcat).
Convert Source Image to Base64 Prepares image for AI based remixing.
Generate Image using NanoBanana Sends the prompt and base image to Gemini Image API for art generation.
Convert Base64 to PNG Converts the AI output to an image file.
Upload to Twitter Uploads generated image to Twitter via media upload API.
Create Tweet Publishes the tweet with attached image.
🪄 How It Works
1️⃣ Schedule Trigger - starts the automation (e.g., hourly or daily).
2️⃣ Define Memecoin - stores your mascot metadata:
memecoin_name: popcat
mascot_description: cat with open mouth
mascot_image: https://i.pinimg.com/736x/9d/05/6b/9d056b5b97c0513a4fc9d9cd93304a05.jpg
3️⃣ AI Agent - prompts Gemini to:
  • Write a short 100 character tweet in Gen Z slang.
  • Create an image generation prompt inspired by current meme trends.
    4️⃣ NanoBanana API - applies your base image + AI prompt to create art.
    5️⃣ Upload & Tweet - final image gets uploaded and posted automatically.
🧠 Example Output
Base Source Image:
Base Image
Generated Image (AI remix):
Generated Image
Published Tweet:
Tweet Example
Example tweet text:
Popcat's about to go absolutely wild, gonna moon harder than my last test score! 🚀📈 We up! #Popcat #Memecoin
🧩 Setup Tutorial
1️⃣ Prerequisites
Tool Purpose
n8n (Cloud or Self hosted) Workflow automation platform
Google Gemini API Key For generating tweet and image prompts
Twitter (X) API OAuth1 + OAuth2 For uploading and posting tweets
2️⃣ Import the Workflow
  1. Download memecoin art generator.json.
  2. In n8n, click Import Workflow → From File.
  3. Set up and connect credentials:
    • Google Gemini API
    • Twitter OAuth
  4. (Optional) Adjust Schedule Trigger frequency to your desired posting interval.
3️⃣ Customize Your MemeCoin
In the Define Memecoin node, edit these fields to change your meme theme:
memecoin_name: "doggo"
mascot_description: "shiba inu in astronaut suit"
mascot_image: "https://example.com/shiba.jpg"
That’s it - next cycle will generate your new meme and post it.
4️⃣ API Notes
