Extract business card data & generate follow-ups with Google Vision OCR & GPT-4 Mini
Created by: Aditya Malur || aditya-malur
Aditya Malur
Last update 3 months ago
This n8n template helps you turn business cards into qualified sales opportunities — instantly.
No more lost leads after events or networking meetups. Just send a business card photo via Telegram, and let AI handle the rest.
The workflow extracts details (name, company, role, email, phone) using Google Vision OCR, analyzes context with OpenAI, and then generates personalized WhatsApp or email messages to help you follow up faster.
Use Cases
Capture leads instantly from events or meetups.
Auto-analyze business card data into structured CRM entries.
Send hyper-personalized WhatsApp messages or emails within minutes.
Ideal for founders, marketers, and business development teams.
How it Works
Trigger: Send a photo of a business card via Telegram.
Extract: Google Vision OCR reads and extracts all text from the image.
Process: The extracted text is sent to an AI agent (OpenAI GPT-4.1-mini) for:
Contact parsing (name, company, role, email, phone)
Business/industry inference
AI-generated personalized follow-up messages
Output: The system returns structured JSON containing:
Email subject & body
WhatsApp draft message
Fit score, opportunities, and next action steps
How to Use
Import the JSON template into n8n.
Add your Telegram Bot Token to the “Telegram Trigger” node.
Add your Google Cloud Vision API key in the HTTP Request node.
Add your OpenAI credentials in the “OpenAI Chat Model” node.
(Optional) Connect the output to Google Sheets, Airtable, or your CRM.
Run the workflow — take a photo of a business card and watch the magic happen!
Requirements
Telegram Bot for image input
Google Vision API Key
OpenAI API Key
(Optional) Integration with CRM or WhatsApp API
Customization Ideas
Replace Telegram with Email or WhatsApp triggers.
Push qualified leads directly into HubSpot or Notion.
Automate multi-step sequences based on AI fit scores.
