Generate Instagram posts with AI quotes & images using GPT & Gemini
Created by: Amir || amandegar
Amir
Last update 13 days ago
📸 Instagram Post Automation Workflow
ℹ️ What is this workflow
This workflow automatically produces daily Instagram posts based on a user-provided prompt and sends them to your email inbox.
Social media creators can use it to generate content periodically and save time.
The email includes:
  • Picture
  • Title
  • Caption
  • Relevant hashtags
You can simply copy and paste the content from the email into Instagram, or go further by connecting it to the Facebook API for full automation.
💼 Business Cases
  • Generating social media posts primarily for Instagram.
  • Integrating with other workflows (trend research, market studies, news feeds) to produce images, statistics, text, or data comparisons for social media.
💰 Business Value
If you produce daily posts and each Instagram post takes around 1 hour to find a quote, create an image, caption, and hashtags, this workflow does it in less than 1 minute.
This saves you:
  • Weekly: 7 hours (1 hour × 7 days)
  • Monthly: 30 hours (1 hour × 30 days)
  • Yearly: 360 hours (12 months × 30 hours)
    At a cost of $20/hour, this workflow saves:
    $7,200 annually (360 hours × $20).
In total, you're saving 360 hours + $7,200 per year, allowing you to focus on other valuable activities.
⚙️ How Does It Work
  1. The workflow runs periodically according to your schedule settings.
  2. Generates a new quote, avoiding duplicates of previously created ones.
  3. Creates an image.
  4. Sends all content by email.
🔗 Integrated Services
  • Local file storage on the hosted platform
  • OpenAI GPT model (customizable to any AI model you prefer)
  • Gemini model for image generation (replaceable with your preferred tool)
  • Email sending via SMTP
🛠 How to Set Up
  1. Install the workflow template.
  2. Configure AI models and set up SMTP credentials.
  3. Create a file on your local installation (/home/node/instagram_posts.txt).
  4. Set up the scheduler.
  5. Test and enjoy.
