Generate and manage short links with GPT-4.1 and data storage
Created by: Nghia Nguyen || nghiaaidev
Nghia Nguyen
Last update a month ago
This AI Agent helps you create short links from your original URLs.
Each generated short link is automatically stored in a database table for easy management and tracking.
How It Works
  1. Provide a long URL to the Agent.
  2. The Agent saves your original link in the database.
  3. It generates a short link in the following format:
Short link:  https://{webhook_url}/webhook/shortLink?q={shortLinkId}
When users open the short link, they are automatically redirected to your original link.
How to Use
  • Send your link to the Agent.
  • The Agent will respond with a generated short link.
Requirements
  • Add your your_webhook_url to the Config Node.
  • OpenAI account
  • Create a database table named ShortLink with the following columns:
Column Name Description
originalLink Stores the full original URL.
shortLinkId Stores the unique short link ID.
Customization Options
  • Add traffic tracking or analytics for each short link.
  • Customize the redirect page to display your logo, message, or branding.
