Beautiful web UI for GPT-4 multi-agent chat with specialized assistants
Created by: Hugo || hugo-misery
Hugo
Last update a day ago
n8n Graphical Input Template - AI Agent Interface
A beautiful, ready-to-use HTML interface for n8n workflows that allows your users to interact with AI agents through a clean web UI. No frontend skills required!
Version
License
🎯 Why Use This Template?
  • No Frontend Skills Required: Get a professional interface without writing React, Vue, or complex JavaScript
  • Real-Time AI Responses: Display AI responses directly in the interface with loading animations
  • User-Friendly: Your clients get a beautiful UI instead of dealing with APIs or command-line tools
  • Plug & Play: Just paste the code in an n8n Code node and connect your AI agents
  • Fully Customizable: Easy to modify colors, add more agents, or change the layout
  • Dark/Light Mode: Built-in theme toggle with localStorage persistence
🚀 When to Use This?
Perfect for:
  • AI Agent Interactions: Let users chat with different specialized AI agents (Database, Web Search, RAG)
  • Customer Support: Route customer questions to appropriate AI assistants
  • Data Collection: Gather information from clients with instant AI-powered responses
  • Customer Portals: Create simple interfaces for customers to interact with your AI automations
  • Internal Tools: Build quick admin panels with AI assistance
📦 What's Included?
  • Text Input Area: Large textarea for user messages
  • Send Button: Main action button with smooth animations
  • 4 Specialized Agent Buttons: Pre-configured for General, Database, Web, and RAG agents
  • AI Response Display: Beautiful response area with agent badges and loading states
  • Project Guide Modal: Built-in documentation for your users
  • Theme Toggle: Dark/Light mode with localStorage persistence
  • Responsive Design: Works perfectly on desktop, tablet, and mobile
  • Font Awesome Icons: Beautiful icons throughout the interface
  • Error Handling: Graceful error messages if something goes wrong
🛠️ How to Use
Part 1: Display the Interface
Create a 3-node workflow to show the UI:
Webhook (GET) → Code Node → Respond to Webhook
Configuration:
  1. Webhook Node (GET):
    • Method: GET
    • Path: /your-interface (e.g., /ai-chat)
    • Authentication: Optional
  2. Code Node:
    • Copy the entire content of main.js
    • Paste it into the Code field
  3. Respond to Webhook:
    • Respond With: First incoming item
    • Response Data Source: Binary
    • Binary Property: data
Part 2: Process AI Requests
Create a separate workflow to handle AI processing:
Webhook (POST) → Switch → AI Agents → Code Node → Respond to Webhook
Configuration:
  1. Webhook Node (POST):
    • Method: POST
    • Path: /webhook-endpoint
    • Response Mode: "Respond to Webhook"
  2. Switch Node - Route by agent type:
    • Rule 1: {{ $json.body.agent_type }} equals general
    • Rule 2: {{ $json.body.agent_type }} equals database
    • Rule 3: {{ $json.body.agent_type }} equals web
    • Rule 4: {{ $json.body.agent_type }} equals rag
  3. AI Agent Nodes (4 nodes, one per agent type):
    • Connect one AI Agent to each Switch output
    • Configure with OpenAI, Anthropic, or local LLM
    • Add tools, memory, system prompts as needed
  4. Code Node - Format the response:
const webhookData = $('Webhook').first().json.body;
const aiResponse = $input.first().json;
return [{
  json: {
    response: aiResponse.output || aiResponse.text || aiResponse.response,
    agent_type: webhookData.agent_type,
    user_message: webhookData.message,
    timestamp: new Date().toISOString()
  1. Respond to Webhook - Send back the formatted response
🔧 What to Update
In main.js
Line 847 - Update webhook URL to match your n8n path:
const WEBHOOK_URL = '/webhook/webhook-endpoint';
Line 20 - Customize project name:
const projectName = "AI Assistant Hub";
Lines 34-56 - Change colors (optional):
:root {
  --primary: #6366f1;        /* Main accent color */
  --primary-hover: #4f46e5;  /* Hover state */
  --background: #ffffff;     /* Background */
📊 How It Works
User visits /your-interface
Sees the chat interface
Types message + clicks agent button
POST to /webhook/webhook-endpoint
  "message": "Find users in database",
  "agent_type": "database",
  "timestamp": "2025-10-19T..."
Switch routes to Database AI Agent
AI Agent processes with tools/memory
Code Node formats response
Returns { "response": "Found 10 users..." }
Interface displays response with badge + animation
🎨 Customization Guide
Add More Agents
Copy an agent card (lines ~700-730) and modify:
<div>
  <div>
    <i></i>
  </div>
  <div>Custom AI Agent</div>
  <div>
    Specialized in your custom task.
  </div>
</div>
Then add CSS for the new agent type:
.agent-card.custom-agent::before { background: #f59e0b; }
.agent-card.custom-agent:hover { border-color: #f59e0b; }
.agent-icon.custom-icon { background: linear-gradient(135deg, #f59e0b, #d97706); }
.response-agent-badge.custom-badge {
  background: rgba(245, 158, 11, 0.1);
  color: #f59e0b;
And update the Switch node to handle the new agent type!
Modify Text Content
  • Modal Guide: Lines ~754-810 - Update help text
  • Placeholder: Line ~689 - Change textarea placeholder
  • Subtitles: Lines ~677, ~693 - Modify section descriptions
Change Agent Descriptions
Lines ~705, ~717, ~729 - Update the description text for each agent.
📱 Built-in Features
  • Enter to Send: Press Enter to send (Shift+Enter for new line)
  • Escape to Close: Press Esc to close modals
  • Loading State: Animated spinner while AI processes
  • Agent Badges: Color-coded badges show which agent responded
  • Clear Button: Easily clear responses to start fresh
  • Theme Persistence: Theme choice saved in browser
  • Smooth Animations: Professional transitions and hover effects
  • Error Handling: User-friendly error messages
💡 Example Workflow Ideas
Customer Support Bot
  • General Agent: Answers common questions
  • Database Agent: Looks up order status, account info
  • Web Agent: Searches knowledge base articles
  • RAG Agent: Searches company documentation
Data Analysis Tool
  • General Agent: Explains data concepts
  • Database Agent: Runs SQL queries on your data
  • Web Agent: Fetches external data sources
  • RAG Agent: Searches analysis reports
Internal Admin Panel
  • General Agent: General assistance
  • Database Agent: User management queries
  • Web Agent: Check external integrations
  • RAG Agent: Search internal docs/wikis
🐛 Troubleshooting
Response not displaying?
  • Check that Code Node after AI Agent formats response with response field
  • Verify webhook URL in main.js matches your n8n webhook path
  • Check browser console for JavaScript errors
AI Agent not responding?
  • Ensure Switch node routes match agent types: general, database, web, rag
  • Verify AI Agent nodes are properly configured with API keys
  • Check n8n execution logs for errors
Styling issues?
  • Clear browser cache
  • Check that Font Awesome CDN is loading
  • Verify CSS variables are properly defined
📝 Technical Details
  • Framework: Pure HTML/CSS/JavaScript (no dependencies!)
  • Icons: Font Awesome 6.4.0
  • Browser Support: All modern browsers (Chrome, Firefox, Safari, Edge)
  • Mobile: Fully responsive with touch support
  • File Size: ~1050 lines (~35KB minified)
🤝 Contributing & Support
This template is designed to be simple and self-explanatory. The code structure:
  1. Lines 1-23: Configuration and setup
  2. Lines 24-640: CSS styles
  3. Lines 641-751: HTML structure
  4. Lines 752-1048: JavaScript functions
Feel free to modify and adapt to your needs!
📝 License
Free to use and modify for your n8n workflows. No attribution required.
