AI industry trend monitor 24/7 across X, Gmail, and websites using GPT-5
Created by: LeeWei || leeweihernandez07
LeeWei
Last update 21 days ago
Overview of the n8n Workflow
This n8n workflow automates the daily monitoring of trends across X (Twitter), newsletters, and websites. It runs on a schedule, fetches data from configured sources in Google Sheets, processes it using AI agents for extraction and analysis (including browser automation and web search), and appends relevant updates to a Google Sheets database. The workflow handles data aggregation, filtering for recency, and deduplication, ensuring users receive concise, actionable insights on topics like AI news or market opportunities.
How it Works
• The workflow triggers daily, pulling configuration from Google Sheets (e.g., X accounts, newsletters, websites).
• It scrapes recent X posts, fetches newsletter emails via Gmail, and browses websites using an AI agent to extract updates.
• All data is aggregated, analyzed by an AI agent (with optional web research for context), and filtered for relevance.
• Extracted data points (name, description, source, date) are saved to Google Sheets for easy review.
Set Up Steps
Setup takes about 15-30 minutes, focused on credentials and API keys. Detailed node guidance is in the workflow's sticky notes—clone it, add credentials, and test. The workflow is plug-and-play once imported; only edit prompts or sources as needed.
⚙️ AI Trend Listener: Monitor Updates 24/7
Automate daily scanning of X (Twitter), newsletters, and websites for trends, saving key updates to Google Sheets.
🧑‍💻 Author: LeeWei
🚀 Steps to Connect:
  1. Google Sheets Setup
    • Duplicate the template sheet.
    • Add OAuth2 credentials in n8n for read/write access to the sheet.
    • Populate the X, Newsletters, and Websites tabs with your sources (e.g., usernames, email filters, URLs).
  2. Apify Integration (for X Scraping)
    • Sign up at apify.com and generate an API token.
    • Paste the token into the HTTP Request node's credentials (header auth: Authorization Bearer).
    • Test with a sample X account to fetch recent posts.
  3. Gmail Setup (for Newsletters)
    • Create OAuth2 credentials in n8n with scopes for reading emails (gmail.readonly).
    • Connect to the Gmail nodes; ensure your newsletters are in the inbox.
    • 💡 Filter for specific senders in the Newsletters sheet tab.
  4. Airtop Browser Automation
    • Register at airtop.ai, generate an API key, and create a profile.
    • Paste the key into the Airtop nodes' credentials.
    • The browser agent handles website navigation—test with a sample URL.
  5. OpenAI API Key
    • Generate a key at platform.openai.com.
    • Paste it into the OpenAI (or equivalent chat model) nodes.
    • Use for AI agents analyzing data; select a model like GPT-4 for best results.
  6. Perplexity AI (for Web Research)
    • Sign up at perplexity.ai/api and get an API key.
    • Paste it into the Perplexity AI tool node.
    • Enables context gathering during analysis—use sparingly for cost.
Plug and Play Instructions
Clone the workflow JSON directly into n8n—all nodes (schedules, agents, aggregators, HTTP requests) are pre-wired and ready. No re-setup needed beyond the steps above. Key editable fields (found in sticky notes):
  • Your Instructions Node: Browser Prompt
    Customize the website extraction (default: "Search all the latest AI news from this page and its child pages"). Example: Change to "Find new real estate listings" for market-specific monitoring.
  • Your Instructions Node: Analysis Prompt
    Adjust the AI filtering criteria (default: Focuses on AI developments). Example: Add rules for crypto signals or finance news exclusion/inclusion.
  • Google Sheets Nodes (Get X Accounts, Get Newsletters, Get Websites)
    Update the sheet IDs or tabs if using a custom duplicate; add more sources directly in the sheet.
  • Schedule Trigger Node
    Change the daily time (default: 6 AM) or frequency for more frequent runs.
  • Filter Node (for Tweets)
    Tweak the 24-hour recency check if monitoring longer periods.
Test with the default AI focus: Run manually and check the Data Points sheet for updates.
Potential Customizations
  • Add More Sources: Expand Google Sheets tabs for new categories (e.g., Reddit via HTTP) and add aggregation branches.
  • Switch AI Models: Replace OpenAI with another provider in the chat model nodes.
  • Enhance Output: Add notifications (e.g., Slack node) after saving to Sheets.
  • Scale Monitoring: Increase Apify maxItems or add loops for larger datasets.
Considerations and Improvements
  • Rate Limits: Apify and Perplexity have usage caps; monitor for heavy queries. Airtop starts with free credits (10,000).
  • Data Volume: Handles moderate sources; for high-volume, batch process or filter stricter.
  • Privacy: Data passes through third-party APIs—avoid sensitive topics.
  • Enhancements: Integrate email notifications for urgent trends or add deduplication logic for cross-source overlaps.
This workflow keeps you ahead in fast-moving fields like AI or markets, delivering daily insights without manual checking. Questions? Test it in n8n!
