Track AI model executions with LangFuse observability for better performance insights
Created by: Artem Makarov || makarovartyom
Artem Makarov
Last update a month ago
About this template
This template is to demonstrate how to trace the observations per execution ID in Langfuse via ingestion API.
Good to know
  • Endpoint: https://cloud.langfuse.com/api/public/ingestion
  • Auth is a Generic Credential Type with a Basic Auth: username = you_public_key, password = your_secret_key.
  • Trigger: the workflow is executed by another workflow after an AI run finishes (input parameter execution_id).
  • Remove duplicates
    Ensures we only process each execution_id once (optional but recommended).
  • Wait to get execution data
    Delay (60-80 secs) so totals and per-step metrics are available.
  • Get execution
    Fetches workflow metadata and token totals.
  • Code: structure execution data
    Normalizes your run into an array of perModelRuns with model, tokens, latency, and text previews.
  • Split OutLoop Over Items
    Iterates each run step.
  • Code: prepare JSON for Langfuse
    Builds a batch with:
    • trace-create (stable id trace-<executionId>, grouped into session-<workflowId>)
    • generation-create (model, input/output, usage, timings from latency)
  • HTTP Request to Langfuse
    Posts the batch. Optional short Wait between sends.
Requirements
  1. Langfuse Cloud project and API keys
  2. n8n instance with the HTTP node
Customizing
  1. Add span-create and set parentObservationId on the generation to nest under spans.
  2. Add scores or feedback later via score-create.
  3. Replace sessionId strategy (per workflow, per user, etc.). If some steps don’t produce tokens, compute and set usage yourself before sending.
