Twitter content automation with Gemini AI for tweets, images, and engagement
Created by: Kamran habib || virtualdepth
Kamran habib
Last update a month ago
## | N8N Workflow | AI-Powered Twitter Automation with Content Generation and Engagement 🚀
This n8n template automates Twitter (X) activity — from generating tweet content with AI to engaging with posts and even sending DMs — all powered by Google Gemini or OpenRouter AI.
It’s designed for creators, marketers, brands, and agencies who want to automate social media presence with authentic, on-brand AI content and engagement.
How It Works
  • The workflow begins with a form trigger, where users input their topic, tone, and action type (Tweet, Engage, or DM).
  • Those inputs are passed into Workflow Configuration, which sets key parameters like max tweet length and model URLs.
    Depending on your chosen action:
  • Post Tweet: AI generates a tweet under 280 characters and can attach an image.
  • Engage with Posts: AI can like, retweet, or reply to niche-relevant content.
  • Send Direct Message: AI drafts a personalized DM for outreach or networking.
  • If your workflow includes visuals, the AI Agent - Create Image From Prompt node builds a detailed image prompt (based on your topic and instructions) and sends it to Google Gemini or other image APIs.
  • The HTTP Request - Create Image node generates a custom image via an external model (default: Pollinations.ai).
  • Finally, all tweet text and image data merge together in Merge Tweet Text and Image, before being posted directly via the Create Tweet node.
How To Use
  • Download and Import the JSON workflow into your n8n interface.
  • Set up the following credentials:
  • OpenRouter API for text generation.
  • Google Gemini (PaLM) for chat and image prompt creation.
  • Twitter OAuth2 API for posting and engagement actions.
  • Configure your form input fields (Topic, Tone, Action, Instructions).
Enable or disable the nodes you want:
  • Create Tweet → To post automatically.
  • Twitter Engagement Tool → For likes/retweets/replies.
  • Twitter DM Tool → For automated DMs.
  • Trigger the Twitter Content Form via n8n’s web interface.
  • Enter your content preferences and submit.
  • The workflow generates your tweet text, optionally creates a matching image, and posts or saves it automatically.
Requirements
A Twitter Developer Account (with OAuth2 credentials).
A Google Gemini or OpenRouter account with text and image model access.
(Optional) Connection to Pollinations or another AI image generation API.
How To Customize
  • Update “Fields – Set Values” node to change:
  • Default image size (1080 × 1920 px).
  • Model name (e.g., “flux”, “turbo”, “kontext”).
  • Modify Workflow Configuration to tweak AI parameters like:
  • imageGenerationChance (default: 0.3).
  • maxTweetLength (default: 280).
  • Replace Google Gemini Chat Model with any supported model such as OpenAI GPT-4 or Mistral.
  • Adjust AI Agent - Create Image From Prompt system message for your preferred image style or guidelines.
  • Toggle which Twitter actions are active — Post, Engage, or DM — to tailor automation to your goals.
